Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > J.A.F - Just Another Flasher > J.A.F. By Jafsupport.com
Old 07-29-2008, 10:50   #1 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,993
Arrow JAF Exe 1.98.56 ready to download
JAF Exe 1.98.56 ready...
- improved BB5 usb flashing (6220c and E66 supported). Thanks to "The SAINT" for beta testing.
Unpack in JAF folder. YOU MUST HAVE JAF SETUP 1.98.52 INSTALLED.
JAF1.98.56.
The Following 78 Users Say Thank You to Javajohn For This Useful Post:
Old 07-29-2008, 11:03   #2 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
Here is the log for successfully flashing of E66 on this version...
JAF version 1.98.55 beta2
Detected PKEY: GSMAXIS
Card life counter: 85.13%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 6.85.10.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\V102.07.81\rm343_102.07.81_prd.c00
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\V102.07.81\rm343_102.07.81_prd.v04
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-343\V102.07.81\rm343_102.07.81.01U
PRESS POWER ON THE PHONE NOW!!!
Searching for phone...Detected P-KEY: 9000E322
Init usb communication...
Found
Starting DEAD USB phone flashing...
Using 006.044.048
Elf2flash 07.11.000 test 3
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting..............Phone prepared OK!
Waiting for the phone to boot...
Searching phone...Found!
Status byte: 0600
Selecting CMT flash...Result: 0000
Phone is in flash mode...
CMT blocks: 795, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-343\V102.07.81\rm343_102.07.81_prd.c00...
Erasing cmt zone 00040000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00A00000 - 0759FFFF ... Erase result: 0000
Erasing cmt zone 0F1C0000 - 0F8BFFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-343\V102.07.81\rm343_102.07.81_prd.v04...
Erasing cmt zone 05420000 - 0759FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-343\V102.07.81\rm343_102.07.81.01U...
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS*CORE
Sending CMT HASH for SOS+ROFS
Sending CMT HASH for SOS+ROFX
Write result 27: 1700
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: V 102.71.821
03-07-08
RM-343
(c) Nokia
APESW: 102.07.81
VariantSW: 102.07.81
Prodcode: 0565859
DCT4/BB5 counter: 15821
Done!
PS : Thnx to Mr JAF for is gr8 support...
The Following 16 Users Say Thank You to The SAINT® For This Useful Post:
Old 07-29-2008, 14:38   #3 (permalink)
Member: 21937
Thanks Meter: 279
please , still not fixed 6500s and 6280 use ini and chose flash files problem
Old 07-29-2008, 15:30   #4 (permalink)
J.A.F.'s Avatar
Member: 71180
Thanks Meter: 811
This is no bug... You have problems with your installation path. Make sure you have the correct ini file and write permision. I already post logs with this working.
JAF
Old 07-29-2008, 17:05   #5 (permalink)
.:Towhid:.'s Avatar
Member: 304260
Sonork: 100.1593127
Thanks Meter: 355
I try to flash 6500s but after write mcu jaf interface auto closed..............
Old 07-29-2008, 17:49   #6 (permalink)
Member: 21937
Thanks Meter: 279
JAF
o.k
i see the problem now
but just know on build .50 its working o.k
RM-78 and others get default install dir in
C:\Program Files\Common Files\Nokia\DataPackage\Products
and not in
when i moved the folder to C:\Program Files\Nokia\Phoenix\Products
all working well
but on .50 build its working on original dir
Old 07-29-2008, 18:37   #7 (permalink)
Registered User
elmostapd1980's Avatar
Member: 194178
Sonork: 100.1594302
Thanks Meter: 34
52&53&54&55&56
may by one setup can do all of this updates
Old 07-29-2008, 18:54   #8 (permalink)
CPUKILLER's Avatar
Member: 76257
Thanks Meter: 77
thi problems occurs in 2 situations 1st-if u have dual windows loaded ,2nd-some setups go to common files folder in--- c\programfiles\commonfiles---so solution is simple select manually and set ini or simply cut and paste from commonfiles to nokia products folder ,hope this helps---cpukiller
Old 07-31-2008, 13:49   #9 (permalink)
Member: 303848
Thanks Meter: 14
cant flash e66...any procedure how to flash.
JAF version 1.98.56
Detected PKEY: 90000***
Card life counter: 96.75%
Detected UFS_USB V2.6 (c) SarasSoft 2005. version: 01.B0, Driver version: 0, Library version: 0
USB Cable Driver version: 7.0.2.0
Current path C:\Program Files\Nokia\Phoenix\Products\ changed to
C:\Program Files\Common Files\Nokia\DataPackage\Products\
Searching for phone...Detected P-KEY: 90000593
Found
MCU SW version: V 102.71.821
03-07-08
RM-343
(c) Nokia
HW version: 0500
PCI version:
RFIC version:
DSP version:
APE SW Core version: 102.07.81
APE Variant version: 102.07.81102.07.81_v16
APE Test version: RM343ENO7411718213.017
Retu version: 15
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
Production serial number: MEJ323565
Product code: 0558511
Module code:
Basic production code: 0552842
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 352943020142902
IMEI spare to net: 3A 25 49 03 02 41 92 00
IMEI SV to net: 33 25 49 03 02 41 92 10 F0
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0558511
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81_prd.c00
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81_prd.v16
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81.02U
Done!
Changing flashing settings...
Reading...
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81_prd.v14
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81.01U
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\352943020142902_CRT_backu p_2030317.pm
Done!
Backup CRT OK!
Found
Reading SW version...102.71.821 102.07.81
Reading battery value...3764 mV
Init usb flashing...
Reading flashid...
CMT: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
APE: 00000000 <=> Flash -> not detected
Verifing ADL communication... Status byte 7
Phone rebooted but not in flash mode...
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\352943020142902_CRT_backu p_2047317.pm
Done!
Backup CRT OK!
Found
Reading battery value...3750 mV
Reading flashid...
Old 07-31-2008, 13:52   #10 (permalink)
Member: 202306
Thanks Meter: 13
Help
I Have N91 Vibratig Problem Please Help Me
Old 07-31-2008, 13:56   #11 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
o.k
and not in
all working well
Thank you, just copied the folder and jaf accepted the fles.
Old 07-31-2008, 15:35   #12 (permalink)
The SAINT®'s Avatar
Member: 111249
Thanks Meter: 531
JAF version 1.98.56
Found
03-07-08
RM-343
(c) Nokia
HW version: 0500
PCI version:
RFIC version:
DSP version:
Retu version: 15
Tahvo version: 22
APE HW version: 256
Module code:
Flash code:
Order number:
ATO:
Default SN type:
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Done!
Reading...
Backing up CRT...
Reading IMEI...
Done!
Backup CRT OK!
Found
Reading flashid...
Backing up CRT...
Reading IMEI...
Done!
Backup CRT OK!
Found
Reading flashid...
Try using the DEAD USB option to flash the phone.
Old 07-31-2008, 17:35   #13 (permalink)
Member: 303848
Thanks Meter: 14
change cable driver according to your logs cable driver.
here the results
JAF version 1.98.56
Card life counter: 96.35%
FBUS INTERFACE NOT CONNECTED!!!
Found
03-07-08
RM-343
(c) Nokia
HW version: 0500
PCI version:
RFIC version:
DSP version:
Retu version: 15
Tahvo version: 22
APE HW version: 256
Module code:
Flash code:
Order number:
ATO:
Default SN type:
LOCK STATUS:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Done!
Reading...
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81.04U
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\352943020142902_CRT_backu p_04118.pm
Done!
Backup CRT OK!
Found
Reading battery value...3755 mV
Reading flashid...
Using 006.044.048
CMT RAW loader...
Error booting phone...
with dead usb same results
JAF version 1.98.56
Card life counter: 96.07%
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81_prd.v13
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81.05U
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-343\rm343_102.07.81.03U
Found
Using 006.044.048
CMT RAW loader...
Old 07-31-2008, 18:27   #14 (permalink)
Member: 303848
Thanks Meter: 14
another cable driver. same results
Searching for phone...Detected P-KEY: 90000***
Found
Using 006.044.048
CMT RAW loader...
Old 08-01-2008, 05:11   #15 (permalink)
Member: 403881
Thanks Meter: 80
First i installed 1.98.52 and its cable driver also , now i am trying to open 1.98.56 exe its showing error
ERROR:CAN NOT FIND INTERFACE DDL Please suggest what to do.
Regards,
JAF Setup 1.98.58 ready To Download !!!! Javajohn J.A.F. By Jafsupport.com 8 10-04-2015 09:43
JAF Exe 1.98.56 ready to download Javajohn Service Products News & Updates 0 07-29-2008 10:56
JAF Exe 1.98.55 ready to Download !!!! Javajohn J.A.F. By Jafsupport.com 10 07-29-2008 06:58
JAF Exe 1.98.55 ready to Download !!!! SHANU Service Products News & Updates 0 07-28-2008 19:59
Page generated in 0.35554 seconds with 9 queries
