Sony Ericsson ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc. AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608. New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800. CR 16B Inside:T66,T600,T600c,T602. ODM:J100. C Series: C510, C702, C901, C902, C903, C905
G Series: G502, G705
K Series: K630, K660, K850
T Series: T700, T707, T715
V Series: V640
W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
Z Series: Z750, Z770, Z780 |
04-18-2005, 11:19 | #1 (permalink) |
Junior Member Join Date: Jan 2005 Location: Florence Age: 50
Member: 109819 Status: Offline Thanks Meter: 0 | flash v800 to z800 with davinci Thanks, Massimo |
04-19-2005, 17:38 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: 0xBA, 0xBE Age: 38
Member: 73743 Status: Offline Thanks Meter: 2 | Hello, do not tell people what to do The flash is perfectly safe. No doubt in your case samething went wrong and the erom was erased from firmware - phone needs to be flashed with good main and FS (DO NOT COMPLETE/FINALIZE) then flash erom recovery file. Then you can finalize. and reflash if you wish. |
04-19-2005, 17:51 | #4 (permalink) | |
Junior Member Join Date: Jan 2003 Location: Sweden Age: 41
Member: 20579 Status: Offline Thanks Meter: 0 | Quote:
I really hope you can help me out then.. Ill start from the beginning... Im using a dss-25 syncstation and a V800 First I just wanted to know if the syncstation worked with the davinci program so I pressed the "read cid" and it worked.. But after it was done.. The phoneŽs camera led was "lighted" and the phone wouldnt turn on.. so i tried to flash with the phones cid number which is 29 and the vodafone firmware which it is.. but then after a while i get a lot of "Error! Block not accepted" and nothing happens... so i cancelled and tried z800 cid29 and the same problem occured and then the z800 latest firmware with cid36 and also the same.. 3credits gone But worse is the phone.. It wont turn on again... OOh btw.. The phone is unlocked since before if that helps?? | |
04-19-2005, 18:04 | #5 (permalink) |
Member: 73743 Status: Offline Thanks Meter: 2 | Well it sounds like typical erom erased. You need to find the special erom file on the davinci server and then flash it. Sorry i am not familiar with davinci. |
04-19-2005, 20:55 | #6 (permalink) |
Member: 109819 Status: Offline Thanks Meter: 0 | it's ok something gone wrong, i have the cellphone dead (so it seems) . so i need to reflash it with original v800 vodafone fw without finalize and then reflash with recovery, then reflash with z800 fw?? that's the way?? Thanks, Massimo |
04-19-2005, 21:35 | #7 (permalink) |
Member: 20579 Status: Offline Thanks Meter: 0 | I have no idea Ive been trying and trying and wasting a lot of credits now :/ Be sure to reply if it worked out ok? If I find anything that helps I will reply.. |
04-20-2005, 11:53 | #11 (permalink) |
Member: 20579 Status: Offline Thanks Meter: 0 | @gbrooks3 I did as you told me yesterday but it didnt help.. i still got lots of Error! Block not accepted Error! Block not accepted Error! Block not accepted in the finalization step and I think iŽll wait for the other usb cable to arrive until i test further and im not using this app for v800 again.. not for now that is @maxx1973 have you managed to fix yours yet?? |
04-20-2005, 12:50 | #12 (permalink) |
Member: 109819 Status: Offline Thanks Meter: 0 | not yet!! i'm trying to use recovery v800 cid29 and the process starts ok but after 1 min it lost the phone connection because (i think) the battery charge is low; tonight i get from a friend his v800 to use like charger and with full charge battery i try to do it again and hope to set the phone ready for a new flash. send results late ciao ciao |
04-21-2005, 13:37 | #13 (permalink) |
Member: 109819 Status: Offline Thanks Meter: 0 | no way!!! try recovery cid29 with davinci no finalization ok, than flash with multi server z800 r2y... when arrived to start file system is gone....any idea?? |
04-21-2005, 13:51 | #15 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi donŽt worry, I had seen phones dead in this way, use davinci server to flash v800 firmware R1D, is at davinci server, notice this is eu5 vodafone customized firmware, donŽt complete phone! once you successfully flash the phone use setool client to upload v800_db2000_erom file (this one is free thanks to the_laser), once this file is uploaded (takes few seconds) power on the phone, is alive again but with R1D vodafone firmware, if you wanna get rid of vodacrap/turn on z800 just flash other firmware, operations will take 1 credit from davinci, the second way to revive is use the recover R1J flash from davinci, just flash it and phone will get back to life, best regards Invisible |
Error (303109) flashing V800 to Z800, dead | recoba23 | SonyEricsson (USB-Smart) | 5 | 07-31-2006 23:26 |
V800 to Z800 with UFS3+HWK | tigran80 | Sony Ericsson | 1 | 03-21-2006 13:32 |
Flashing V800 to Z800 | enzino | SonyEricsson (USB-Smart) | 5 | 12-07-2005 10:05 |
How to Flash V800 to Z800 | jaca11 | Sony Ericsson | 1 | 11-07-2005 05:59 |
flash v800 to Z800 | mazbaly | Sony Ericsson | 5 | 09-29-2005 23:45 |
