Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Griffin Products > MT-BOX
Old 11-21-2005, 21:41   #1 (permalink)
Member deceased !!
andro's Avatar
Member: 10248
Thanks Meter: 25
**MT box cables modifications, test points and pinouts**
Modification for BB5 phones cables recomended for all Nokia boxes in GSM market
Explanation:
Nokia BB5 new PCB version N70, 6681, 6630 phones DOES not have OVER voltage protection (recomended MAX 4,3V for BB5 phones).
To protect phones from POWER GLICH we are made some protecting modification for BB5 cables.
BR GT
The Following 4 Users Say Thank You to andro For This Useful Post:
Old 12-21-2005, 23:23   #2 (permalink)
Member deceased !!
andro's Avatar
Member: 10248
Thanks Meter: 25
!!!!! Important !!!!!
Never connect and disconnect USB, when you have phone attached to box.
BR GT
Old 03-17-2006, 20:33   #3 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Boot error 0003 with k750i and other phones who use new connector.
Just replace black wire to other resistor side
Old 03-30-2006, 13:41   #4 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
If you have problem with ARM inside when try to flash ARM phones:
Loader status problem. 0006
Please check your cable
Old 06-29-2006, 15:20   #5 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
If this message always appears on MT box Nokia software:
Phone is in: Phone is not responding, power on phone!
Please check pin 10 and pin 1 on your box
Old 07-06-2006, 19:57   #6 (permalink)
MicrostarGSM®'s Avatar
Member: 18855
Thanks Meter: 1,938
For Some new BB5 models please read this link
N80 Cable Modification
Modifcation for E61
Cable Modification For 6131,6125 and E60
For others new BB5 please check as below
Make sure the BSI to GND is 68K resistor normaly some cable comes with only 39K so you have to change to 68K
and from BSI to BSI box normaly it dosen't have you need to add either 5.1K or 7.5K , if you have put the 5.1K it not shown test mode ot local mode then use the 7.5k. Make sure the phone must be in test mode or local mode inorder to have working cable your your MT-Box
Below attachment is for others BB5 models Please Test and post result and logs for the phone info and flash log
regards
The Following 4 Users Say Thank You to MicrostarGSM® For This Useful Post:
Old 08-06-2007, 13:50   #7 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
OK man the file who you need is here. TEST AND POST RESULT
File Type: rar BB5Erase_UNI_rapido.rar (395 Bytes, 2885 views)
Old 08-30-2007, 06:05   #8 (permalink)
Member: 18855
Thanks Meter: 1,938
here is the pinout of 6110n. some cable only come wiht 5 pin so that you need to add one pin
The Following User Says Thank You to MicrostarGSM® For This Useful Post:
Old 09-10-2007, 09:28   #9 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
this is pinout for 6085
The Following User Says Thank You to 911GT For This Useful Post:
Old 09-14-2007, 05:40   #10 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Nokia 6280 cable scheme for MT box
The Following User Says Thank You to SoftMobile For This Useful Post:
Old 09-14-2007, 05:53   #11 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Nokia 6300 cable schematic.
Old 09-16-2007, 19:51   #12 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
Nokia 5200-5300 cable by DR Sema
Old 09-16-2007, 22:52   #13 (permalink)
SoftMobile's Avatar
Member: 9290
Sonork: 100.57287
Thanks Meter: 35
LG KE series cables for Griffin server
LG KE USB cable
LG KE MT box cable for GT virtual com
Old 09-17-2007, 16:36   #14 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
this is a n75 pinout
Old 09-19-2007, 09:44   #15 (permalink)
911GT's Avatar
Member: 409197
Thanks Meter: 75
E65 Pinouts
all another shematic needed for a make a cable have on a http://griffinteam.net
How to unlock N70 with noox box? by usb cable or test point? mymiela0419 NoooX Box 5 10-13-2008 20:35
..::codes + Cables + Devices + Test Point And Many More::.. chiragp Main Sales Section 0 10-06-2007 16:48
Test point and battery cable daigram for e-gold /s-gold akhil_bbsr E-Gold Based Phones 0 11-13-2006 07:55
cable of test point helllllllllllp electrosoft SAGEM JTAG UNLOCKER 9 08-27-2005 08:48
e606/808 unlocked by cable or test point ? luckyfahad79 Redbox 5 06-13-2004 19:33
Page generated in 0.22975 seconds with 10 queries
