Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Direct Codes ★ | Direct Unlock Source | Mark Forums Read |
QUALCOMM Models (3G) SGH-Z105x, SGH-Z107x, Z110, Z130, Z140, Z300, Z320i, Z500, Z510, ZM60, ZV10, ZV30, ZX10. |
02-03-2006, 09:39 | #1 (permalink) |
Junior Member Join Date: Feb 2006
Member: 228485 Status: Offline Thanks Meter: 0 | SGH-Z500 IMEI/BT lost Phone is still working (looks fine) but there is a problem with BT and sync. I followed some threads here and found out that I have lost IMEI and BT. I have loadet this and that, tried this and that but without success. Is there a general (working) hint, what software (working) do I need, where can I get the software........ Anytime i try to set the EMEI I get the message EMEI not rechable My equipment: Notebook with COM1, 9 pin plug with PIN2-3, XPprof/SP2 latest USB Driver from Samsung, QUALCOMM Driver; *#123580# PS: Is there anybody who can code me the new BT address My EMEI is 356456/00/048714/4 thank you very much assakgojo |
02-25-2006, 14:21 | #2 (permalink) |
Junior Member Join Date: Dec 2005
Member: 205345 Status: Offline Thanks Meter: 0 | USE CABLE WHICH CAME WITH TELEPHONE Download driver from here: http://www.rexnet.it/firmware/utilit...usb_driver.zip from cellular WITHOUT SIM, BATTERY INSERTED, USB CABLE DISCONNECTED digit *#1546792*# go to Internals, master key is *#2456987*# select Test mode select Common select USB configuration select Qualcomm USB confirm and connect usb cable to telephone install drivers when requested open certain program..., http://www.************.com/forum/ar...p/t-16864.html select correct modell of cellular, click Write IMEI insert IMEI (without last number after / ) check at its correct and confirm when finished disconnect cable digit *#1546792*# go to Internals, master key is *#2456987*# select Test mode select Common select USB configuration select Samsung USB confirm and reboot cellular Source: ANVI Forum: http://www.anvi.it/forum/index.php?showtopic=25506 For bluetooth: First of all read from back of telephone, last part of IMEI: (example: iif imei is 355000/00/056789/1 you need only 56789) add 56789 with 4980736 note number what you get (example: 5037525) swithc on telephone *#1546792*# Internals *#2456987*# Test Mode Version Information BD address (Read current, if it´s wrong like 00:12:47:00:00:01) Write BD address Input part1: insert 4679 WHICH IS FIXED!!! hit enter. Input part2: insert calculated number (in examble: 5037525) hit enter. hit OK, and address is recovered. (in example: 00:12:47:4CD5) Source: http://www.anvi.it/forum/index.php?s...luetooth&st=60 Last edited by juuso113; 02-25-2006 at 15:32. |
02-25-2006, 14:51 | #3 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Thankx for INFO and the Link in ****** plz proivide name for it thankx 4980736 note number what you get this number is constant for every one if not how we get it Last edited by Amir-SkillZ; 02-25-2006 at 15:05. |
02-25-2006, 15:36 | #4 (permalink) | |
Member: 205345 Status: Offline Thanks Meter: 0 | Quote:
it is: mobile - files of course without spaces, but anyway you find that also from source page. I only translated those from Italian. | |
02-25-2006, 15:53 | #5 (permalink) | |
No Life Poster Join Date: Aug 2003 Location: Town City Age: 54
Member: 37735 Status: Offline Sonork: 100.103255 Thanks Meter: 205 | Quote:
02-25-2006, 15:57 | #6 (permalink) | |
XXXXXX ARE=Mobile -.files,.com But the main file there is NSDONGLE (http://rapidshare.de/files/6388471/....tml)CRACKED.In this case not Really Important. | |
03-01-2006, 20:37 | #7 (permalink) |
Member: 228485 Status: Offline Thanks Meter: 0 | oops thank you very much, but i found help 2 weeks ago in another thread. PS:Nice bluetooth solution !!!!!!! By the way, I'm using REXNET "Z500REX03" but there is no "german T9" in it. Is there a better one available ?? |
03-05-2006, 00:14 | #8 (permalink) |
Member: 205345 Status: Offline Thanks Meter: 0 | I have z500REX04 and there it seems working. Version 04 is released in January. Download: http://www.rexnet.it/firmware/sgh-z500/z500rex04.zip there is also rexW4 with full wallpaper. Download: http://www.rexnet.it/firmware/sgh-z500/z500rexw4.zip |
Thread Tools | |
Display Modes | |
Samsung SGH-Z500 | karlx | QUALCOMM Models (3G) | 9 | 09-26-2005 16:27 |
Samsung SGH-Z500 complete unlock solution | reefer45 | QUALCOMM Models (3G) | 92 | 07-29-2005 23:25 |
[Request] SGH-Z500 Flash please | Z500 | QUALCOMM Models (3G) | 0 | 07-09-2005 17:22 |
Dead SGH-Z500 | Jocke | QUALCOMM Models (3G) | 0 | 06-30-2005 11:52 |
who know correct to flash samsung sgh-z500? | paul8888 | QUALCOMM Models (3G) | 0 | 06-16-2005 19:00 |
