Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Closed Thread
    Old 08-28-2006, 13:32   #1 (permalink)
    DrMobile's Avatar
    Member: 5932
    Thanks Meter: 1,694
    General Informations regarding CID, CDA, COLOR, GDFS etc.
    CID = This "number" defines the version of SE's protection present in the phone.New CIDs are deployed from time to time, for the sole reason of preventing them from beeing unlocked/flashed/tampered with by non-SE service tools. Current CIDs in use by SE are 29/36/37/49. SE-based LG/Sharp phones use the same system (but different versions). The OTP (One Time Programmable memory) and EROM of a phone might be protected by different CIDs, usually the case in newer K600s/K608s.
    CDA = This "number" defines which variant of a specific firmware a phone is supposed to have.It lets among others SEUS (Sony Ericsson Update Service) know which language-pack/branding/bandlocks a phone is to be flashed with. A generic (unbranded) K750 for use in Scandinavia will be CDA102337/12, whilst a Telenor-branded K750 will be CDA102338/62. Both will be flashed with the same languages/dictionaries, but the latter will be flashed with Telenor-branded firmware.
    BLUE/BROWN/RED:This "color" defines what kind of phone we are dealing with.BLUE phones has been assembled at the factory, but never been programmed with software/GDFS/IMEI (remember kids: the IMEI is stored in the OTP (One Time Programmable memory))BROWN phones are "developer phones", for testing. Less restrictions are present, as these are used for "debugging/beta" purposes. As of CID36, a phone has to be converted to BROWN to unlock it.RED phones are your typical retail ones.
    GDFS:This is the phones "stash", where all settings and calibration data is stored (this also goes for the firmwares IMEI-resource as well as the SIMlocks). Similar to other brands use of NVRAM (Non-Viotile Random Access Memory).
    IMEI = International Mobile Equipment Identity.A 15-digit number which includes information on the origin, model, and serial number of the device. The model and origin comprise the initial 8-digit portion of the IMEI, known as the "Type Allocation Code/TAC". The remainder of the IMEI is manufacturer-defined, with a "Luhn check digit" at the end (which is never transmitted). The "Luhn check digit" is calculated from the rest of the IMEI.
    It should be noted that in SE-based phones, the IMEI is stored in two places, the OTP (One Time Programmable memory) and GDFS. The GDFS IMEI is normally read from the OTP, but this can be circumvented by SETool function to "change" the IMEI. This patches the firmware into allowing different OTP/GDFS IMEIs. It is the GDFS IMEI that is reported to the network, so changing this will "de-bar" blocked phones. SEUS is not fooled by this, on the other hand, and it should also be noted that doing this is illegal in most countries.
    EMMA = Service software/solution by SE themselves. Protected by the EMMA smartcard to prevent non-licensed usage. Current version is EMMA3, though EMMA2 is still alive (but kinda useless on newer phones). The EMMA smartcard contains an algorithm that allows EMMA to communicate directly to/with the phones CID, so performing operations the way they were intended. The smartcard and its algorithm has not been cracked. Current EMMA access levels exists:Service Update - Can't unlock phones.Service Update Pro - Can't unlock phones.Network Operator - Can't unlock phones (but sure as hell can lock them ).Service Center Std - Can't unlock phones.Service Center Rc - Can unlock phones, as they have a special version of the smartcard with a CSCA key.Research & Development - Can unlock phones, as they have a special version of the smartcard with a CSCA key.
    DB2000, DB2010, DB2020 = SEMC (Sony Ericsson Mobile Communications) hardware platforms. It's something similar to chipset in PC.DB2000 (another name is Marita) is a GSM+3G(UMTS) capable platform, SE K600/K608/V600/Z800/W900, Sharp 802sh, 902sh, 903sh and LG 3G phones are based on it.DB2010/2012 (Marita compact) is GSM-only, non-3G, platform. Most not very old and modern SE phones like K300,K500,K700,K750,S700,W300,W550,W800,Z520,Z530 are based on this chipset.DB2020 is the newest product of SEMC. K800, K790, K610, Z710 etc, Sharp 904sh feature this most secure (from SE's point of view) platform.
    The Following 203 Users Say Thank You to DrMobile For This Useful Post:
    General Informations regarding CID, CDA, COLOR, GDFS etc. Sonu Jawed Sony Ericsson 1 11-09-2008 01:22
    General Informations regarding CID, CDA, COLOR, GDFS, A2 etc hackgsm SETool2 0 09-04-2008 23:39
    General Informations regarding ActiveSync, ROM, CID lock, Bootloader etc. ::.::RAMJAN::.:: HTC & PDA WM( With Touchscreen) 0 08-18-2008 10:38
    general information help (c350) adamjweaver Motorola P2k 1 09-12-2003 15:35
    Page generated in 0.30110 seconds with 9 queries
