06-21-2007, 05:58 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 44
Member: 52956 Status: Offline Thanks Meter: 49 | K1 dead after change IMEI!!!!!!!! I have K1 that after change IMEI dead boot:0A.B2 sw version:R4527_G_08.12.17R AND AFTER IMEI CHANGE STAY AT BOOT AND BOX SHOW FOR THIS MODEL YOU MUST USE TESTPOINT ! FOR IMEI CHANGING IN K1 WE MUST USE TP? |
06-21-2007, 07:51 | #2 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Yes,tested by me with testpoint,works 1000%.The reason why your phone is dead is because you disconnect phone when program asked for testpoint.Now try to repair pds with testpoint and see if your phone powers on.If not then write 1FF file and repair pds again. |
06-21-2007, 13:39 | #4 (permalink) | |
Member: 52956 Status: Offline Thanks Meter: 49 | 0A.B2 Quote:
and my phone power on but after again change imei phone goes to boot mode................... any idea | |
06-27-2007, 15:54 | #7 (permalink) |
Freak Poster Join Date: Dec 2006
Member: 420649 Status: Offline Thanks Meter: 414 | Make CORRECT PROCEDURE and connect phone WITH TESTPOINT when software ask for that and all will be ok. And bootloader WILL BE CHANGED on phone after IMEI change, and with CHANGED BOOTLOADER you CAN NOT HAVE ANY TEXT on LCD screen in bootloader mode! You can do this procedure even now, when phone is with CODE SIG ERR ... So, in small words, just REPEAT IMEI change procedure, and follow CORECTLY software instructions (specialy when software ask to connect phone WITH TESTPOINT). K1 change IMEI procedure is well tested by us on many available firmware versions and is working well, ... but you have to know how to make CORRECT TESTPOINT on K1 phones to be able to change IMEI ... |
06-27-2007, 18:54 | #8 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | hey... see this tread http:///vbb/showthread.php?t=416110 and GSMLover2010 for solve your problem just reflash your phone with FF, some flashes here http://www.*****moto.com/forums/down...p?do=cat&id=60 Good Luck!!! |
06-29-2007, 14:54 | #9 (permalink) | |
Member: 420649 Status: Offline Thanks Meter: 414 | Quote:
all blackberry models dead after change imei with new version | serllito | FuriousGold | 11 | 01-17-2010 16:18 |
Dead BB 8700 after changing IMEI...is it now trash? | cracker_jack | FuriousGold | 21 | 04-08-2009 12:02 |
k800 dead after change imei | falah1 | SETool2 | 12 | 10-12-2008 14:54 |
K1 Dead after unlock with Smart-clip | .::MoBiLeDoC::. | Smart-Clip | 65 | 09-22-2007 10:37 |
L7 dead after chang imei | ...:::JamalMustafa:::... | Ultima Box Light | 0 | 06-29-2007 12:03 |
