Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultima Box Light
Old 06-21-2007, 16:59   #1 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
error chang imei z3
chang imei z3 R452B error 20070306 like chang imei ?
Establish connection to handset
FLASH Interface established ok
Read handset bootcore version
Bootcore version on handset: 0300
Sending RAMDLD to handset
RAMDLD started ok in handset
Read flash from handset
Power down handset
Err no: 20070306
help !!!
br
nafg
Old 06-21-2007, 20:19   #2 (permalink)
monedadeoro's Avatar
Member: 60640
Thanks Meter: 20
i have same problem ,mbe are a bug in software
Old 06-22-2007, 16:29   #3 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
Hey Manole, is this a bug? if do ..is there any solution?? or we r doing bad the process thanks in advance
B.R.
Nafg
Old 06-25-2007, 18:34   #4 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
@manole , no solution for z3 imei chang ?????
br
nafg
Old 06-27-2007, 05:47   #5 (permalink)
Member: 321523
Thanks Meter: 60
Dear all, i am new in this thereads,i have a model z3 for unlock ,pls tell me is the testpoints required for unlock or not because when i connect the handset it is not found a required hardware.
Old 06-27-2007, 08:26   #6 (permalink)
Member: 255072
Thanks Meter: 46
u can see at tp selection button has been selected then must be use tp
Old 06-27-2007, 15:22   #7 (permalink)
UBL Support's Avatar
Member: 420649
Thanks Meter: 414
What is firmware version on your phone?
Did you selected Z3 model in software?
Flash with 1FF file from support then try change IMEI again, it should work.
Old 06-28-2007, 20:40   #8 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
i have try with many flashes with the file 1ff and i always get the same error. any solution?
Power down handset
Err no: 20070306
thanks in advance
b.r.
NAFG
Old 06-29-2007, 14:14   #9 (permalink)
Member: 420649
Thanks Meter: 414
Power down handset
Err no: 20070306
thanks in advance
b.r.
NAFG
You started phone on FIRST STEP in Testpoint mode (and UBL software NOT say to do that)!!!
This is NOT OK because UBL software cannot read FW version from phone!!!
Start phone in NORMAL or FLASH mode (on first step connection) and in Testpoint mode ONLY AT SECOND STEP (whan software ask you do do that) and all will work well.
Old 06-30-2007, 18:40   #10 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
i try with this 2 software please let me know what iam doin wrong or the correct procedure
z3 boot 0AC0
R452B_G_08.02.0CR_GSTCPRIMSTPELA0DD
R452B_G_08.01.05R_GSTCPRIRTGB094
b.r.
NAFG
Old 07-04-2007, 03:23   #11 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
2.16 thank ubl team
chang imei z3 is good works
Switch handset to TCMD interface
TCMD Interface established ok
Read phone informations
Model: Z3
IMEI: 3530250xxxxxx
User Code: 1234
Security Code: 000000
Firmware: R452B_G_08.01.05R
Flex Version: GSTCPRIRTGB094 - 2.0.1.2.3.2.0.5.0.0.L.0˙˙˙˙
Operation completed with success
Read Flash chip type and ID
Flash chip ID detected: 0x00898810
Write Bootcore zone on flash chip
Power down handset
Power down handset
Adr patch nullimei: 10921864
Adr patch BMI BNE: 2548E
Adr patch R0: 2549B
Adr fake jump: 13F81141
Adr to patchbuf_3: C82
Adr to patchbuf_4: 1010C26C
Write flash to handset
Power down handset
Power down handset
br
nafg
Old 07-04-2007, 06:11   #12 (permalink)
Member: 516179
Thanks Meter: 3
Help as(like) change does of imei of z3 please
Companion me podrias to explain step along step of since(as) you they do them z3 with the ubl since it(he,she) gives the same mistake that was giving him(her) austed previously for faor him(her) agradesere his(her,your) help, regards to my me
Old 07-04-2007, 06:44   #13 (permalink)
HAROON's's Avatar
Member: 100592
Sonork: 1578498
Thanks Meter: 245
no solution for z3 imei change yet
best of luck
Best Regards
GSMCrazy1
Old 07-04-2007, 06:47   #14 (permalink)
nafg's Avatar
Member: 196727
Thanks Meter: 419
es con la vercion 2.16 muy facil solo conecta con test point para que quede en modo boot z3 luego escribes el imei que quieras y apretas en WRITE IMEI depues sigues los pasos que aparecen en el programa y con eso ya tendras tu imei nuevo
it easy jhust connect with tp so u can connect in boot mode z3 then u write the imei that u want and press WRITE IMEI then u just follow the steps that the program will show
br
yes i nafg
Old 07-04-2007, 14:53   #15 (permalink)
Member: 516179
Thanks Meter: 3
I change of imei z3
muchas gracias compaņero pero yo realice esos pasos y segi las instrucciones del sof de la ubl pero cuando llega al final ma da error este error creo que ati tambien te ha pasado anteriormente compaņero o es que el cambio de imei lo realizaste con la version 2.16, saludos
Thank you very much companion but I realize these steps and segi the instructions of the sof of the ubl but when I come ultimately ma mistake gives this mistake I believe that ati also companion has happened to you previously or is that the change of imei realized with the version 2.16, regards
error changed imei lg gb125 cellcarcol Z3X-Team Products 1 12-04-2009 23:44
error change IMEI nokia 1208, Please Help !! oberacel Universalbox 0 03-20-2009 00:35
1110b error change imei! pilin123 Universalbox 2 09-21-2007 17:09
Error changing imei to a V3 killer84p Smart-Clip 4 03-09-2007 10:26
error changing imei nafg Cruiser Suite 1 12-23-2005 16:16
Page generated in 0.31830 seconds with 11 queries
