06-27-2007, 19:54 | #2 (permalink) |
Crazy Poster Join Date: Oct 2006 Location: Rosario - Argentina
Member: 381423 Status: Offline Thanks Meter: 3 | Please, I require that you should be very nice of indicating graphically the steps to change the imei of the K1 with our tool. From already thank you very much |
06-28-2007, 09:42 | #3 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | 1 - First dissasemble phone 2 - Connect ubl testpoint adaptor 3 - Connect ubl easy tp usb power cable (AT163) 4 - Leave power off 5 - Connect mini usb 6 - Hold * and # key and click power key on power cable 7 - Motorocker 2.15 will show "K1 BOOT" 8 - Enter 14 digit desired imei 9 - Click WRITE IMEI and leave process to run 10 Motorocker will ask to put phone in flash mode again 11 - Turn off power on easy tp power cable 12 - Hold * and # key and click power key on power cable 13 - Click OK and leave process to run 14 - Now Motorocker will ask to connect phone with testpoint 15 - Turn off power on easy tp power cable 16 - Hold tp button in on tp adaptor and press power on easy tp cable 17 - Click OK !!!!!!!!!!!DONE!!!!!!!!!!!!! |
06-28-2007, 13:15 | #4 (permalink) | |
No Life Poster Join Date: Jan 2003
Member: 20069 Status: Offline Thanks Meter: 131 | Quote:
Br the_frightener | |
06-29-2007, 04:51 | #5 (permalink) | |
Freak Poster Join Date: Jan 2007
Member: 435806 Status: Offline Thanks Meter: 10 | Quote:
br | |
08-03-2007, 22:41 | #8 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | K1 Imei Without TP!!!!!!!! Just follow this instructions given for UBL support, 1. Connect powered up phone and press Enter Blank 2. Wait software message "Set Blank Mode completed ok 3. Remove cable and battery 4. Insert cable and battery (LCD will be blank) 5. Wait software to detect phone then Write IMEI but if you change imei before unlock, your mobile will be locked.... after change imei use magic tp for unlock.... thats all.... |
08-11-2007, 19:17 | #9 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 163678 Status: Offline Sonork: 57856848 Thanks Meter: 15 | take this Note: It is also possible to change IMEI Without using TP on K1 and Z3. BUT, only one time without TP (when phone is in ORIGINAL state). Procedure is this: 1. Connect powered up phone and press Enter Blank 2. Wait software message "Set Blank Mode completed ok 3. Remove cable and battery 4. Insert cable and battery (LCD will be blank) 5. Wait software to detect phone then Write IMEI You have to NOT use Leave Blank after new IMEI was written!!! If you want to change IMEI second time on same phone, (phone is with changed IMEI already) you will have to use TP. |
pls help--how to repair imei in v3e and k1, imei in both sets are 0000123456 | shahi | Smart-Clip | 1 | 03-01-2010 09:17 |
K1 imei change procedure?!!! | meisam | Smart-Clip | 1 | 05-21-2009 13:14 |
Motorola K1,z3 Change Imei | accejen | Motorola P2k | 2 | 08-07-2007 20:59 |
