Old 09-10-2007, 15:37   #1 (permalink)
Member: 49752
Sonork: QQ:1474246528
Thanks Meter: 6,085
F.A.Q About BB5 Contact Retailer Locked For All Provider & RPL WRITE.
There Is No Full And Perfect Way To Solve But This Can Help To Solve...
Info About Contact Retailer In BB5 & SP Area Damaged & RPL Write Phone.
Few Things You Have To See Before Repair.
1 Phone IMEI Is Damaged Or Not? F.E 123456789012345
2 Phone Sp Area Is Damaged Or Not? F.E Config key -FFFFFFFFFFFFFF & PROVIDER - unknown
ex1
CONFIG KEY: 0000000000000000
PROVIDER KEY: 0000000000000000
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
ex 2
CONFIG KEY: FFFFFFFFFFFFFFFFF
WITHOUT REPAIRING THIS PART FORGET DOING ANYTHING ELSE.
IF YOU HAVE ONE OF THIS MEANS YOUR PHONE IS ON CONTACT SERVICE OR LOCKED TO ALL PROVIDERS.
SIMLOCK REPAIR MAY HELP LIKE SL REPAIR BUT ITS CAN ONLY REPAIR 308 NOT WATCH DOG TIMER. SO PHONE WILL KEEP OFF IN 3 TO 13 MIN.
BEST AND EASY WAY IS CALCULATE RPL FROM ASK AND WRITE IT.
3 Bb Self Test You Can Do With Service Option.
Security Test
Simlock Test
4 What Can We Do If IMEI Is Damaged?
A.Simple And Easy Way To Repair Is If You Don't Have Backup. Calculate Bb5 Ask 2 Rpl And Write It.
B.Free Way Is Downgrade Phone Then Check. If IMEI And Sp Area Still Damage Update Back And Use Ask 2 Rpl.
5 What If We Have Sp Area Damaged? (F.E Configkey –FFFFFFFFFFFFF & PROVIDER - unknown )
A. Simple And Easy Way Is If You Have Backup Of Pm 308(Eeprom In Hex 134) Restore It With Write Pm. Remove Phone Insert Battery And Plug Again And Test Phone.
B. If You Don't Have Backup Just Use Bb5 Ask 2 Rpl To Repair It.
6 What If I Have Backup Rpl And Not Have Pm Backup?
A. Backup Rpl Is For Certificate To Repair Or Restore. So In This You Can Restore IMEI Of Phone But You Can't Restore Sp Area.F.E Configkey –FFFFFFFFFFFFF & PROVIDER - unknown
7 What If I Have Backup Pm And Don't Have Rpl?
A. You Can Restore Or Repair Sp Area But U Can't Restore Or Repair Phone IMEI (Certificate) With Only Pm You Need Rpl Backup Or CALCULATED RPL ONLY WAY.
8 Can I Restore Rpl With Usb Cable?
A. No You Can't Write Rpl (Certificate) Via Usb Because Its Need Active Flash Mode.
9 What I Do After Rpl Write Still Contact Retailer?
A.Most Phone Need To Rewrite Pm Field [1] And [309] For Writing This Fields Pm File You Have To Do SX4 With Supported Tools Then Do Fast Do Not Restart Or Off Phone Before Writing Pm File.
B.Most Phone Can Repair With Downgrade And Write Rpl Then SX4 Write Pm To See If Same Then Update Back Then See If Solved Or Not.
10 How To Get This Pm Section?
A.Read Any Working Phone Pm 1 To 512.Save To Pc.Open It To Notepad And Remove Field - [308] From It Save Again...Now U Can Us It.
Note That If U Forget To Remove 308field From That Pm Before Writing U Get Damaged Sp Area Phone After Writing This Pm.
B.You Can Also Use Only Pm Field - [1] And Field - [309] Also.
11 Can I Use Any Firmware Pm To Any Firmware?
A. Some Phone Have Security Check For Rf Value.So Test If Not Work U Need Correct Version Pm.
12 What If Still Have Problem Contact Retailer?
A. Do Self Test And Check St Security Test Is Failed Or Not?If Yes Then Read Post Again.If No Then Read B And C
B. If Self Test Pass Then Do Factory Default And After That Do File System Format .
C. As I Think Its Possible From Hardware Also So Check Hardware Section For More Help.. As I Think From My Side [Retu Ic] Responsible.
D. bandlock data can make problem of contact service. so for example only you have 5310 contact service.you have universal box read cert with it and check in it "CCC_DATA_x" and "HWC_DATA_x" this data hold bandlock as we found in POINT 25.so you must write bandlock data rpl for this model and test it.. AND IT MUST WORK...
here is success stories so all of readers can see where and what can be done if you don't understand by reading. this point.
http://forum.gsmhosting.com/vbb/show...85#post4028285
13 What If I Get Can't Decode At Rpl Write Or Corrupted?
A.Best Way To Solve Contact Rpl Supplier.There Is No reason To Give Answer About This Problem Because JAF Team Not Making Any Rpl By Them Self..
14 What Is SX4 ?
A. SX4 Is Card By Nokia Work With Fps10 Fps8 To Calculate RPLS And Give Authorization Password To Phone.
15 Why We Need SX4?
A. To Change/Rewrite In Pm(Eeprom) Sections Fields.
. SX4 Calc Password For Phone. Because Nokia Have Protected Pm(Eeprom)Field [1] And [309]
B If We Need To Rewrite This Filed We Need To Use SX4.
16 Why Some Phone Have Problem Rpl Write But Still Sp Area Damaged?
A. Simple Your Can See Your Phone IMEI Is Restored Or Not. If It Was Damaged. Then Rewrite Rpl And Test Phone With Battery.
If Its Not Damaged Then For Sending Sp Area We Need Local Mode Or Test Mode Because Phone Don't Accept Sp Area In Normal Mode.
17 What Is reason To Use Rpl?
A. Many reason To Use Rpl I Write Here.
[1]To Repair Config key = FFFFFFFFFFFFFFF
[2]To Repair Provider = Any Digit Or Number Or Show Unknowed
[3]To Repair Phone IMEI Damaged To 123456789012345.
[4]To Repair Contact Retailer Come Because Field[1] And Field [309]Damage And Corrupted
[5]To Repair Finished Counter Keypad Counter = 3/3 Fbus Counter = 10/10
18 How To Know That Rpl Come Is For Locked Phone Or Unlocked Phone?
A. There Is 2 Way..
[1]Just Write Rpl And See Lock Area
[2]Real One. Ask Any Nokia Access Owner To See Your Phone Warranty Before Process For Rpl. He Will Show This Type Of Info.
Serial Number:
35938*************** <------Your Phone IMEI.
Warranty:
No <--------Your Phone Warranty .
Warranty Class:
Standard 15 (Shipment + 15 Months) <--------- Warranty Time
Product Type:
Rm-78 <--------- Phone Nmp Code For Firmware
Handset:
6280 <--------- Phone Model Name.
Product Code:
052***x <--------- Product Code For Sales At Which Country.
Start Of Warranty:
27-03-2006
End Of Warranty:
27-06-2007
Ship-To Country:
Ae-United Arab Emirates <------- Sales Country This Phone Belong To This Country.
Ship-To Customer#:
Factory Simlock:
N <---------------- This Is Most Important For Us. Its Show Factory Lock Status N = Not Locked Y = Yes Locked
use this link to get ur warrenty info. HERE
19 How To Bring Phone To Local Mode Or Test Mode At Fbus Cable?.
A. You Need To Do Modification At Cable Bsi Wire To Bsi Pin And Also Have To Do Modification At Bsi Pin To Gnd Pin. Modification Need Resistor Value 7.5k to 10k [test which is working for ur phone]For Bsi Pin To Bsi Wire Come From Rj45 Cable.68k Value For Bsi Pin To Gnd Pin At Service Cable.
Note: I added image file to show more clear info. Please see this image file to understand more.also some phone have different place bsi line you can see at battery or service cable before applying this.
20 What Is Local Mode & Test Mode? How Many Modes In Bb5?
A. Here Is Info Please Look There.
21 Where To Get Working And Tested Modified Pm For BB5 Phone ?
A. http://www.gsmchevli.com/support/ AT BB5PM FOLDER.
B. http://www.gsmchevli.in/support/ AT BB5PM FOLDER.
22 How Many Way Exist To Unlock BB5 Till 12 March 2008?
A. http://forum.gsmhosting.com/vbb/show...69&postcount=4
23 how to TEST BB5 FULLY IN SOFTWARE OR WRITE MODIFIED PM WITHOUT SX4 OR REPAIR VARIANT DATA DAMAGED PHONE OR DOWNGRADED PHONE WITHOUT DOWNGRADE TICK.
A.http://forum.gsmhosting.com/vbb/show...91&postcount=4 words first & only at gsmhosting.
B. Update on this method as you all know when phone is damaged imei condition i give name "Bypass Security Mode".
We are able to write any pm we want Without any authorization. so main thing is how to bring phone in "Bypass Security Mode"? Answer is simple Just Damage IMEI and it will skip all check same time.
Now some newbie also asking how to damage IMEI? anyway all that non reading guys have answer here.
1. Backup CRT OR other words your phone certificate which have NPC bla bla other data. we need ONLY NPC DATA is main thing to backup all other is easy to recover without lost $$$ money i mean.
2. Write THIS (<---download link) RPL as Plan RPL.
3. Restart phone and try now to write pm or any other test you want to do.
4. MAIN THING RESTORE YOUR NPC BACKUP(your rpl backup) TO RESTORE ORIGINAL IMEI TO PHONE, IF YOU DO NOT DO THIS THEN PHONE WILL OFF IN 3 TO 30MIN.
write modified pm solution was first in gsmhosting then all other forum and team copy it.
idea by karwos and method by me.
solution since 21st May 2008, 04:11 PM
24 what is bb5 rpl backup and calculated rpl? what are the difference?
A. backup rpl is what we do with flashing tool. can backup your NPC, VARIANT AND OTHER Certificate in flash mode..
B. universal box read cert option can read both cert and sim lock data in same way.. that's really best way to do backup since jaf is not updating this part don't know why, but its really best for backup phones. no more pm need if you backup with universal box read cert..
C. calculated rpl come from nokia which we send public id. its have npc = imei, sp lock = sim lock area, sim lock key = calculated sim lock key for sending sim lock data, super lock dongle key = security by nokia to sending sim lock special key , some other certificate which help to make phone watch dog timer OFF.
25 How can i change bb5 phones band? or how can i change BB5 850/1900mhz to 900/1800mhz?? WORLD FIRST AND ONLY IN WORLD. ONLY AT GSMHOSTING.
A. very simple method found today you just need to rewrite any working phone CCC DATA & HWC DATA..
for example ONLY FOR 5310B DO NOT TRY FOR OTHER PHONES SAME RPL. :
you have 5310b phone you want it to work with 900/1800mhz
write this rpl with jaf tick on plan rpl...
now test phone must work with 900/1800mhz 100%..
tested and proved by user ".::NaNTeC::." BIG THANKS TO HIM FOR THIS DETAILS.
and i made it for him.
links for bandlock rpl
http://gsmchevli.com/support/BANDLOCK/
http://gsmchevli.in/support/BANDLOCK/
solution at this forum since "26th Dec 2008, 03:00 PM"
26 What is SL2 phones? why its not repair or restore sp are after restoring 308 pm backup?
A. SL2 phones are new security by nokia which use different simlock structure then normal slpl phones.
B. SL2 phones use 2 fields as secure simlock information. pm section 120 and pm section 308 to repair or restore to original status that phone you have to restore both section and all fields in it.
C. SL2 if you have pm section 308 backup only you can't restore your phone to original stat its show only contact service. at that case you need to restore pm section 120 or buy ask 2 rpl.
D. SL2 phones are supported in many tool this days so unlocking is possible without any problem.
E. There is SL3 phones special simlock structure which is unknown and still not possible to hack or crack so no way to unlock accept via imei and provider codes.
27 What is Easy way to repair Contact Service in BB5 Phones SL1 SL2 Phones.?
A. If Sim lock Test Failed Make Simlock RPL rewrite it to repair SIMLOCK TEST FAIL. with supported tools.
B. If Super dongle show failed or phone do not accept SX4 repair SUPER DONGLE with supported tools.
C. if Security Test Failed Use Custom Super dongle autho(Custom sx4) To authorize phone Write Modified PM.
D. If all test passed still contact service try to write BANDLOCK.RPL for your MODEL. flash phone with latest version or Check in hardware...
if you still need more help please post log with self test with supported tools.
28 HOW SL3 (BRUTE FORCE) UNLOCKING WORKS?.
ANSWER
1. with supported tools make SL3BF LOG FILE for decrypted HASH saved in pm 120.
2. use decrypted sha1 hash to bf(BRUTE FORCE) 15 digit master sp.
3. use master sp to calculate all 7 level code with supported tools.
if you have new model bandlock or pm files and you like to send us please send ur bandlock.rpl or model.pm tested file to this email with model name.
please send only new which is not exist at server.
stanner dot austin at gmail dot com
That's All.
As I Think This Is Perfect Information And May Help All.
BEST REGARDS.
Gopal Chevli.
Last edited by stanner_austin; 04-09-2011 at 12:53. Reason: Added 28 point SL3 BF INFO
The Following 793 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-10-2007, 16:16   #2 (permalink)
Member: 143385
Thanks Meter: 30
If i have like this in nokia 6234 it is possible to repair only with ask to rpl servis?
LOCK STATUS:
The Following 17 Users Say Thank You to protons For This Useful Post:
Old 09-10-2007, 16:24   #3 (permalink)
Member: 49752
Thanks Meter: 6,085
LOCK STATUS:
read point 5
my bro try to read again u will learn more then u think with reading only.
The Following 12 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-11-2007, 12:36   #4 (permalink)
dr.deathx's Avatar
Member: 567616
Thanks Meter: 157
thanks stanner good idea
but ASK T0 RPL is 20 £
in thsi forum we talk about free free free not a buy
The Following 7 Users Say Thank You to dr.deathx For This Useful Post:
Old 09-11-2007, 13:19   #5 (permalink)
Member: 49752
Thanks Meter: 6,085
Originally Posted by Pandemonio100 View Post
Ok tanks to Stanner Austin for good explanation i sticky thread.
thanks
here is another one..
http://forum.gsmhosting.com/vbb/show...36#post2706336
@dr.deathx
sorry we don't writed here price problem..
its just for help to users who facing this problem from long time.
The Following 15 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-11-2007, 15:32   #6 (permalink)
Member: 123133
Sonork: 100.999
Thanks Meter: 911
Very Good & HelpFull Information For EveryOne
@stanner_austin
and as i knows about you are a good programmer and very good expert in gsm
if u countinue this kind of greatest helps ..i hope u will be MODERATOR bcoz u are deserved.
really thankfull to u .. (bcoz i always get working solutoins from u )
WBR
Kuku
The Following 9 Users Say Thank You to .:Kuku:. For This Useful Post:
Old 09-11-2007, 17:42   #7 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
Thanks Meter: 658
@stanner_austin
WBR
Kuku
Yes i agree with you kuku bro and have best wishes for Gopal (stanner_austin)
The Following 8 Users Say Thank You to Kanwalgee For This Useful Post:
Old 09-11-2007, 22:36   #8 (permalink)
kaligola's Avatar
Member: 239318
Thanks Meter: 51
what about 12345610654321? no backup or other, phone damaged by owner, can resolve rpl for this stanner?
The Following 8 Users Say Thank You to kaligola For This Useful Post:
Old 09-12-2007, 08:50   #9 (permalink)
Member: 49752
Thanks Meter: 6,085
yes ..point 7 is modified more to help u and all users now its easy to understand.
The Following 9 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-12-2007, 18:55   #10 (permalink)
Member: 49752
Thanks Meter: 6,085
Update Use Full PM file link
MODIFIED PM WHICH I HAVE..
I WILL UPDATE WHEN I GET ..AND I UPLOAD ONLY TESTED ONE..
LINK IS HERE
The Following 25 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-13-2007, 16:33   #11 (permalink)
Member: 519495
Thanks Meter: 10
Where can I make ask to rpl ,Mr Stanner austin?
Can you do ? How much?
Thank you !
The Following 7 Users Say Thank You to tangqitao1860 For This Useful Post:
Old 09-13-2007, 16:35   #12 (permalink)
Member: 49752
Thanks Meter: 6,085
Thank you !
as i think its available from long time..
USE MAGIC BOTTON SEARCH......
or see my location
The Following 8 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-16-2007, 12:40   #13 (permalink)
Member: 149332
Thanks Meter: 7
I have an 5500 with contact retailer , after I unlock with MT-pro , IMEI and SP area is ok , is in contact retailer with field 308 writed back ? After many downgrade and upgrade is same. What can I do? Ask rpl ? PM ?
The Following 5 Users Say Thank You to ottogsm For This Useful Post:
Old 09-16-2007, 12:51   #14 (permalink)
Member: 49752
Thanks Meter: 6,085
read first post again and read point 9
The Following 6 Users Say Thank You to stanner_austin For This Useful Post:
Old 09-18-2007, 23:26   #15 (permalink)
Member: 143848
Thanks Meter: 125
hi
i have one 6233 that was flshed with 6280 version 3.81 ...fone changed imie to 12345****.. then i flashed it back to 6233 5.10, imei was still corrupt but phone was fully turning on and showing corrupt imei.. i bought and write the rpl of jaf but imei remained same.. i flashed again with 5.10 write full pm with universal box .. now fone wont go in test mode... fone wont turn on properly( it turns of after 2 second of switching on ) . i tried to flashe with 5.10 and also tried to downgrade but fone will not do the after flash process on universal box .. can u help me ?
thnx and regards
The Following 11 Users Say Thank You to luckycool For This Useful Post:
Samsung T509 lock for all providers mapalma Samsung Flashers, Software, Firmware. 6 01-02-2009 12:44
New last flowchart for repair bb5 contact retailer morteza-icu Nokia Base Band 5 ( BB-5 ) 0 09-26-2008 17:33
How to know BB5 Contact Retailer from RPL or Rap3 ? waresee Nokia Base Band 5 ( BB-5 ) 3 03-17-2008 09:55
please help about n80 contact retailer what i will do i buy a new rpl software2all Nokia Base Band 5 ( BB-5 ) 11 06-05-2007 10:12
Page generated in 0.47435 seconds with 10 queries
