09-22-2007, 23:51 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2006 Location: Spain
Member: 260694 Status: Offline Thanks Meter: 16 | No way to unlock v3xx with smart tp!! i bought the oficial cable SMART TP from www.aggty******.com to unlock v3xx, and the cable dont do nothing, in smart moto i can just see: Searching for phone...found S Flash Argon switching to flash mode...ok Reading phone boot version...3.02 after that i have black display in test-mode the i bought s-cout to reflash the phone, beacuse without it, i can't flash v3xx my *******r still waiting !!!!!!!!!!!!!!!!!! any prove or foto or video to see the process unlocking v3xx with smart-tp help!! |
09-26-2007, 15:39 | #2 (permalink) |
Junior Member Join Date: Dec 2002 Location: spain Age: 49
Member: 19091 Status: Offline Thanks Meter: 0 | i have this problem too. i buy two smart testpoint 1 -> wire power, wire yelow and wire green, not wire ground Fail always 2 -> wire power, wire yelow , wire green and wire ground Fail always is posible that some models of V3XX is not posible unlock ???? V3XX is unlock 100% versions whit smart-clip ??? |
09-26-2007, 16:21 | #3 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | GSMserver team did not sell a single Smart TestPoint cable yet. We don't bear any responsibility for the items from unknown manufacturer. Also, we always recommend to disconnect LCD from the board to avoid damaging the handset. Best Regards GSMServer team |
09-26-2007, 17:12 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Aqua Project Age: 47
Member: 115242 Status: Offline Sonork: 100.1581364 Thanks Meter: 1,638 | Model RAZRV3xx Firmware R26111LD_U_96.71.95R Switching to flash mode... OK [S Flash Argon] Reading phone boot version... 3.02 i alos have this problem with v3xx |
09-27-2007, 00:47 | #5 (permalink) |
Member: 260694 Status: Offline Thanks Meter: 16 | any prove unlockin v3xx any video proces or picture to unlock v3xx. i had trying evrytihing and always same results: Searching for phone...found S Flash Argon switching to flash mode...ok Reading phone boot version...3.02 i still belive in smart-clip anyway |
09-27-2007, 07:38 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ zablander212, To be able to unlock this phone Smart TestPoint cable should be used. If the procedure done correctly boot version suppose to be read as 0.00. As i can see from your log file it get read as Quote:
Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com | |
09-27-2007, 16:47 | #7 (permalink) |
No Life Poster Join Date: May 2004 Location: Peru Age: 54
Member: 67240 Status: Offline Thanks Meter: 45 | to zablander212 , do not waste time trying to unlock ROM 4 phones, it is a lie from SC team. |
09-27-2007, 22:51 | #8 (permalink) |
Member: 260694 Status: Offline Thanks Meter: 16 | i think it's lie too any body can post a sacssufel unlock for v3xx..!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!! thanks |
09-28-2007, 00:03 | #9 (permalink) | |
Registered User Join Date: Jan 2005 Location: TuNiSiA Age: 43
Member: 111457 Status: Offline Thanks Meter: 967 | Quote:
no one know how can made smart TP cable byhimself !!!!! anyone confirm succeffely unlock Argon based models except sc team !!!??? | |
09-28-2007, 04:13 | #10 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 239212 Status: Offline Thanks Meter: 12 | I think we should all wait for the official SMART TEST POINT CABLE from sc team before we make any conclusions. SC team we are all waiting to test if it really works for unlocking.... |
03-11-2008, 20:17 | #11 (permalink) |
Major Poster Join Date: Jul 2006
Member: 312383 Status: Offline Thanks Meter: 6 | v3xx unlock all v3xx with boot version 3.02 unlock via tp cable i bought from gsm server, AT163 smart TB cable with 3 wire attacht to the rj45 adaptor ,red ,yellow and black, use the red connecting to battery possitive pin,and the yellow use as tp ,connect to pin seven on ic chip ....please follow this link for procedure how to unlhttp://www.boot-loader.com/index.php?option=com_bootloader&task=getpublic&Ite mid=59&source=testpoints&type=dir&direction=forwar d&path=/ock this phone or visit www.boot-loader.com ,i have use this method unlock many v3xx no problem,hope this help. Last edited by mobiletogo; 03-11-2008 at 20:22. Reason: add infor |
03-11-2008, 21:19 | #12 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Port Harcourt Nigeria Age: 51
Member: 197720 Status: Offline Thanks Meter: 24 | i successfully unlocked v3xx phone three days ago although i was a little bit confused where you have typical and untypical mode i chose untypical mode and followed steps my set was successfully unlocked my boot version was 4.07 thanks to smart clip team and all is real |
03-12-2008, 08:42 | #13 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ sonetek, V3xx Untypical meant to be used in case if you have handset from AT&T or Cingular. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-13-2008, 10:54 | #15 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Always Here Age: 37
Member: 333494 Status: Offline Sonork: 100.1607053 Thanks Meter: 190 | Clip serial: ########, version: 4.06, initializing... OK Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... AMD - S71WS512NE0 Reading flash id/2... AMD - S71WS512NE0, OK Phone group: K3,M702iG,M702iS,V1100,V3xx,V6,V9 Hardware IMEI: 354078011788310 IMEI OTP status: locked Security area saved to "PDS for S Flash Argon 354078011788310.mbk" Performing restore from temparary backup file F:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_0803051B64C59ED2.bk_ Restore OK Unlocking phone... OK |
can i unlock v3xx with out tp adoptor. | biochemistali | Smart-Clip | 4 | 06-08-2008 04:56 |
Check It before you start Unlocking/Repairing with Smart-TP cable using Smart-Clip | imran_qasim | Smart-Clip | 0 | 02-10-2008 14:08 |
How to revived dead V3xx with Smart TP? | FMC_GSM | Smart-Clip | 22 | 01-18-2008 03:41 |
can i unlock v3xx with smart clip | nasir iqbal | Smart-Clip | 3 | 08-14-2007 18:30 |
== NO way to unlock 2310 With F1== | bakarioss | Federal One | 3 | 03-30-2007 17:06 |
