10-10-2007, 23:30 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: The Arrivals
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | thx infinity team, unlock now j110 100% thx infinity team now i unlock j110i succes the unoutorized phones i give yesterday customer retourn but have many to unlock. her some succes unlock j110 log COM12 [VCP0] selected Device: SE-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading SE-J110i_eeprom_calibration-1... file saved: backup_SE-J110i_eeprom_calibration-1_20071011-002037.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 36 sec Remove/Install battery now ! first 100% unlocked COM12 [VCP0] selected Device: SE-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading SE-J110i_eeprom_calibration-1... file saved: backup_SE-J110i_eeprom_calibration-1_20071011-002633.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 23 sec Remove/Install battery now ! second 100% unlocked COM12 [VCP0] selected Device: SE-J110i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 039C-000 version sw: KIM-5- Check flash Done Check parameters... reading SE-J110i_eeprom_calibration-1... file saved: backup_SE-J110i_eeprom_calibration-1_20071011-002839.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 17 sec Remove/Install battery now ! third 100% unlocked now work fine ebu mohammed-emin |
10-11-2007, 01:04 | #3 (permalink) |
Registered User Join Date: Feb 2005 Location: Turkiye :islam
Member: 115596 Status: Offline Sonork: [email protected] Thanks Meter: 1,127 | Infinity-Box thanks for the test ---Infinity-Box |
10-11-2007, 01:45 | #4 (permalink) |
Member: 263993 Status: Offline Sonork: 100.1612432 Thanks Meter: 173 | and her log from j120i COM12 [VCP0] selected Device: SE-J120i "advanced chip detection" active Action: unlock Checking data, wait... Boot... Phone should be Switched OFF ! Press Power button now ! loading... Boot Done Check connection... Check connection Done Set baud... Set baud Done Check flash... flash: 89886200010001:89886200000000 flash: Intel Intel std [def 003Fx010000 0008x002000] 4Mb version sw: 032H-000 version sw: MLD-5- Check flash Done Check parameters... reading SE-J120i_eeprom_calibration-1... file saved: backup_SE-J120i_eeprom_calibration-1_20071011-024118.6AE.bin Check parameters Done Check data... Check data Done Writing... flash: 89886200010001:89886200000000 Write: eeprom Writing Done Finished, time used: 18 sec Remove/Install battery now ! 100% unlocked ebu mohammed-emin |
10-11-2007, 03:46 | #5 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Quote:
10-11-2007, 08:15 | #9 (permalink) |
Junior Member Join Date: Jul 2006
Member: 310071 Status: Offline Thanks Meter: 4 | @Montano2 update your box firmware ang use Hmodule_1.03 http://www.infinity-box.com/download...odule_1.03.rar |
J110 unlock via patch 100% worked | adnanali | SETool2 | 26 | 04-26-2012 02:51 |
thanks= infinity team unlock sagam my220x unlock | soy | Infinity-Box | 4 | 03-31-2009 17:46 |
KE850 flashed ok thx infinity team | limem2003 | Infinity-Box | 0 | 01-29-2009 16:05 |
Hello infinity team hear is i am read usha lexus 838b 100% ok set | debmobile | Infinity-Box | 2 | 09-28-2008 08:13 |
thanks infinity team unlock ke970 sucssefull | nazar2008 | Infinity-Box | 9 | 03-11-2008 22:32 |
