11-29-2007, 19:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: City
Member: 12663 Status: Offline Thanks Meter: 78 | Call to RegDBQueryKey failed ????? I receive this message "Call to RegDBQueryKey failed" Also non of HWK SW not works? I have used partition magic to resize some partition, afther that, nothing from HWK SW work! So what now to do? |
12-10-2007, 13:40 | #3 (permalink) | |
Member: 12663 Status: Offline Thanks Meter: 78 | Quote:
Explanation, solution ??? | |
12-10-2007, 13:55 | #4 (permalink) | |
Registered User Join Date: Jun 2005 Location: jamnagar gujarat india
Member: 149938 Status: Offline Thanks Meter: 47 | to hwk supporter Quote:
any help ? | |
12-10-2007, 14:15 | #5 (permalink) |
Product Manager Join Date: Oct 2007 Location: China Age: 39
Member: 608359 Status: Offline Sonork: 100.1576815 Thanks Meter: 6,678 | frist run little setup and install it after installation when update setup is running and read you ufs then install big setup |
12-10-2007, 14:16 | #6 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Where dreams become reality. Age: 54
Member: 4042 Status: Offline Thanks Meter: 24,043 | Its because the solution for "Call to RegDBQueryKey failed" is already posted in the forum, you only need to use the search button. e.g. run update client, even if your HWK is already updated. BTW I cannot see any reason why re-sizing a partiition can cause this issue, since re-sizing a partition should not delete registry entries. Odia. |
12-10-2007, 19:22 | #7 (permalink) | |
No Life Poster Join Date: May 2004 Location: A ROUGH ROAD LEADS 2 THE STARS
Member: 66937 Status: Offline Thanks Meter: 5,053 | Quote: http:///vbb/showpo...5&postcount=76 Munna. | |
12-10-2007, 20:32 | #8 (permalink) | |
Member: 12663 Status: Offline Thanks Meter: 78 | Quote: Afther all uninstall, Installed HWK Support Suite, and Update Client not run afther... Just sand watch show for few sec then nothing... In process files there are started update client, and afther sand watch gone, also process terminated... And it was working all in same win before partition resizing. And if I try to install older version of HWK Suite, PC shut's down. | |
Install cannot continue, report error in support forum" and "call regdbquerykey fail | flydog | HWK | 12 | 10-30-2007 19:49 |
Z520i after flash cant make call to zula | morteza-icu | SonyEricsson (USB-Smart) | 3 | 04-15-2006 14:39 |
A Call To Arms (s56) | duchski | Siemens-Benq Flash Patching | 4 | 05-04-2004 06:50 |
Can i block outgoing calls to certain numbers? | eddie26 | Sony Ericsson | 1 | 03-08-2004 20:43 |
