02-08-2008, 16:18 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Unknown Age: 39
Member: 49752 Status: Offline Sonork: QQ:1474246528 Thanks Meter: 6,085 | Iphone Unlock Without Tp Or Turbo Sim Fully Tested Method. READ IPHONE F.A.Q HERE IF YOU NEVER DONE ANY IPHONE BEFORE. First Check You Should Have Modem Version In Your Iphone 4.2.13g Or 4.3.13g. If You Don't Have No Problem Use 1.1.2 Firmware And Update It With ITunes Link At Down. If You Have Already 4.2.13g Modem Or Newer Do This ================================================== ========================= PART 1 IF YOU HAVE FRESH IPHONE TO UNLOCK & JAILBREAK.. Restore 1.1.1 Firmware Via ITunes Now Do Jail Break Via Classic Way Or My Modified Way. Call On Phone *#301# Now U See Calling Tune.. Use Delete Option And Clear All Number From Screen And Press 0 Now You Can Call It . Now U Get Answer Option Press It Press Hold Now You See You Get Call Again Press Decline Now U See You Can Go To Contact Option At Bottom Thread Option Press + Sing To Add Go To Add Url Type prefs: (Type Same As I Typed) Press Save Once Only Go To Again Add Url Type i.unlock.no (Type Same As I Typed) Press Save. Now Press Save Again You See noname Contact With 2 Url Now Click On 1 Url prefs: Now You Are In Setting. Go To General Click On Auto-Lock To Never Go Back To Setting Go To Wifi Select Your Available Wifi Press Home Button To Main Screen Now You See Activation Screen Again. Press 0 And Call It You See Again You Got Call Accept It And Press Hold You See Its Call You Decline It Go To Contacts Again Now Click On 2 Link I.Unlock.No Now You Get Web Click On First Tab To Jail Break Wait 1minute Only Or More Depend On Your Inet Connection Speed. You Will Again Go Main Activation Screen Again. Don't Worry Its Normal After 1 Or 3 Minutes You Will Be At Main Deskboard Without Activation.. Well You Done Hard Part.. This Is Jail Break Of 1.1.1 Hope You Guys Loved. PART 1 FINISH ================================================== =========================== PART 2 YOU HAVE ALREADY JAIL BREAKED 1.1.1 OR 1.1.2 OR 1.1.3.. THIS IS MAIN PART OF UNLOCK NEW BASEBAND VERSION. Now Use Ibrickr Go To Applications. Install It And Restart Many Time Its Ask. Now Click On Pxl Install And Select Bsdsubsystem-1.5.Pxl All Stuff At My Site Iphone Folder. Its Take Some Time. After It Install Mobileterminal-Svn206.Pxl All Stuff At My Site Iphone Folder After Install Go Back Go To Files In Ibrickr Go To Folder Usr Then Go To Folder Bin Upload All Files From gunlock.rar Upload ICE04.02.13_G.fls Now Back Again Off And On Again. Now You See Terminal Option At Your Deskboard. Go To There Type cd /usr/Bin After Typing Press Return Now You Have To Type Service Unload Command Which You Have To Do Very Carefully If I Writed In Capslock You Have To Write In To. Don't Forget If In Small You Also Type In Small If Caplock You Also Type In Caplock. launchctl unload -w /System/Library/LaunchDaemons/com.apple.CommCenter.plist Ok Now Press Return If You Get # Then You Typed Correct If You Get File Not Found Means U Typed Wrong. Now Type chmod +x gunlock Press Return chmod +x secpack Press Return Now Type Main Command To Unlock gunlock secpack ICE04.02.13_G.fls Now Phone Is Working Wait Till Process Fully Finish. After Finish You Have To Load Service Which You Make Off Now You Have To Type Service Load Command Which You Have To Do Very Carefully If I Writed In Capslock You Have To Write In To. Don't Forget If In Small You Also Type In Small If Caplock You Also Type In Caplock. launchctl unload -w /System/Library/LaunchDaemons/com.apple.CommCenter.plist Bingo Part Is Finish Phone Is Unlocked But Still Some Stuff Is Rest To Make It Fully Working. PART 2 IS FINISH FOR UNLOCK JAIL BREAKED 1.1.1 OR 1.1.2 OR 1.1.3.. ================================================== =========================== PART 3 TO UPDATE UNLOCKED JAIL BREAKED 1.1.1 FIRMAWRE IPHONE TO LATEST.. WITHOUT LET HIM UPDATE PATCHED AND WORKING BASEBAND. Go To Installer And Install Oktopre Update For 1.1.2 If You Forget To Install Oktopre You Have To Do All Again So Becareful After Done Back From Installer Connect Phone To ITunes And Press Shift UPDATE And Its Ask For File Select 1.1.2 File And Let Him Update Firmware ... Now We Back To Activation Screen And 1.1.2 Firmware. Go To Folder 1.1.2 Jailbreak .. All Stuff At My Site At Iphone Folder Open windows.bat Now Press Jailbreak Its Detect Phone And Do His Work After Finish You Get Your Phone Restart Few Times Wait Till Rebooting Is Finish. Now You See Deskboard Is Open Activation Is Done.. Ok Now Connect To Wifi And Install Iworld To Fix Crash And Dialing Number Start Iworld Select Your Country Let Him Restart.. Man Phone Is Working Check Without Turbo Or Xsim Or Any Paying ............ PART 3 IS FINISH FOR UPDATE UNLOCKED JAIL BREAKED 1.1.1 FIRMAWRE IPHONE TO LATEST.. WITHOUT LET HIM UPDATE PATCHED AND WORKING BASEBAND. ================================================== ============================ PART 4 FAST AND PRO METHOD.FOR UNLOCK NEW BOOTLOADER PHONES AND MODEMS. Iphone With Jailbreaked Already. GoTo System Install Bsd Sub System. Add Source To Installer. i.unlock.no GoTo Unlocking Tools Install 1.1.2/1.1.3 OTB Unlock Let Him Run To Do Your Job. FINISH PHONE IS UNLOCKED PART 4 FINISH ================================================== ============================ This is small tutorial I think with this you can unlock your Iphone without losing any single $$$.. MY WEB LINK www.gsmchevli.com/support/ Iphone Folder if you get problem in download there is rar and zip file there. please download that. Big Thanks goes to geohot Without Him No One Using This And Doing Iphone For Free 1.0.2: iPhone1,1_1.0.2_1C28_Restore.ipsw 1.1.1: iPhone1,1_1.1.1_3A109a_Restore.ipsw 1.1.2: iPhone1,1_1.1.2_3B48b_Restore.ipsw Best regards, Gopal Chevli. Hope people love this. Last edited by stanner_austin; 02-12-2008 at 15:54. Reason: updated with faq link |
The Following 15 Users Say Thank You to stanner_austin For This Useful Post: |
02-08-2008, 19:05 | #7 (permalink) |
Freak Poster Join Date: Aug 2005 Location: lebanon Age: 49
Member: 166506 Status: Offline Thanks Meter: 18 | I NEED HELP PLEASE it all went goot untill(Now Click On Pxl Install And Select Bsdsubsystem-1.5.Pxl All Stuff At My Site Iphone Folder. Its Take Some Time. After It Install Mobileterminal-Svn206.Pxl All Stuff At My Site Iphone Folder After Install Go Back Go To Files In Ibrickr Go To Folder Usr Then Go To Folder Bin Upload All Files From gunlock.rar Upload ICE04.02.13_G.fls Now Back Again Off And On Again. Now You See Terminal Option At Your Deskboard. Go To There) i cant found anything on my iphone deskboard can u assist please tx |
02-08-2008, 20:01 | #10 (permalink) |
No Life Poster Join Date: Sep 2003 Location: INDIA
Member: 38103 Status: Offline Sonork: 100.100782 Thanks Meter: 165 | Little bit easier way ! BUT much easier.. add this desbloqueiobr.com.br/rep as source to a Jailbroken 113 and then run AutoGunlock. Do as directed. This works with any version without downgrading. Easier to enjoy GeoHot's way. BR |
Unlock NOKIA BB5 without TP, or opening the phone, or credits ... and many more. | MANOLE | Main Sales Section | 0 | 05-13-2008 19:07 |
bb5 unlocker without tp working or not working | omkarvitekar | Nokia Base Band 5 ( BB-5 ) | 4 | 03-13-2008 18:57 |
v360 in test mode permanent after unlock without TP | crysst | Smart-Clip | 4 | 12-18-2006 15:04 |
