Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Direct Codes ★ | Direct Unlock Source | Mark Forums Read |
02-13-2008, 22:53 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: TUNISIA Age: 44
Member: 160204 Status: Offline Sonork: 100.113150 Thanks Meter: 2,843 | LocostO-CalypsO+HS Hardware Failure Mobile Blocked ,Retour Sav Repair Tool Ready Software Features: -Repair Hardware Failure , Mobile Blocked , Retour Sav,..!! -Software Working with Serial Port ,SMTi Pinout attached for more help P.S : In Prepair Phone Option if Mobile Not Detected Remove Battery & Attach it again Then Power On After Repair : Some Mobiles if show counter leave it till fenish then Put your recieved code from SMTi Software Software tested with a few diffrent models , beta release , SMTi Box must be connected to run Software . Some Cool & Hot News as usual CoMinG SOoN !! Enjoy Download LocostO-CalypsO+HS Repair Tool SAGMASTER TEAM Last edited by DZStorm; 02-14-2008 at 12:14. |
The Following User Says Thank You to DZStorm For This Useful Post: |
02-14-2008, 09:04 | #9 (permalink) |
Member: 160204 Status: Offline Sonork: 100.113150 Thanks Meter: 2,843 | @snsoftkiller You need a connected SMTi to run software then use serial comunication RS232/Unibox,... !! -Software Working with Serial Port ,SMTi Pinout attached for more help |
02-14-2008, 11:31 | #12 (permalink) |
Member: 160204 Status: Offline Sonork: 100.113150 Thanks Meter: 2,843 | @kamo44 Because it's a temporary way used to fix users problems . Because we dont have seperated updates , so till the next SMTi update we will not talk only about one thing |
02-14-2008, 11:46 | #13 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Algeria
Member: 385254 Status: Offline Thanks Meter: 3 | Ok Think you for this helpfull tool, and we hope that this tool become integrated in SMTi software in next update or use the same interface as SMTi in next update of this tool please. |
02-14-2008, 13:17 | #14 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside facebook Age: 47
Member: 250468 Status: Offline Sonork: 100.110362 Thanks Meter: 96 | Quote:
Anyway good work, as always !!! | |
Thread Tools | |
Display Modes | |
Myx-3 Hardware failure mobile blocked | Ary Dieje Sousa | ARM9 BASED M62 / M62+ | 14 | 01-19-2005 12:16 |
MY3026 Hardware Failure Mobile Blocked | doctormike | Infineon C16X M51 & ARM7 M52 BASED | 5 | 01-10-2005 14:03 |
Hardware failure mobile block!!!! | asiamobile | Infineon C16X M51 & ARM7 M52 BASED | 3 | 10-12-2004 13:35 |
Sagem3026-Hardware failure mobile blocked | snehulienka | Infineon C16X M51 & ARM7 M52 BASED | 2 | 02-01-2004 19:22 |
939 hardware failure ,mobile blocked ,what to do? | igor_m | ARM9 BASED M62 / M62+ | 1 | 09-27-2000 08:54 |
