04-17-2008, 15:27 | #1 (permalink) |
Product Supporter Join Date: Mar 2005 Age: 44
Member: 128745 Status: Offline Thanks Meter: 16,936 | How to use PinFinder for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc. We would like to inform all our customers, They can use Infinity Box Auto Pin Finder not only with chinese phones, but with regular models too Auto Pin Finder by Infinity Box Team is a great tool to have in your service center, You do not need to buy new cables when new models are updated by infinity Box. You can just use PinFinder software and correct cable connector in Auto PinFinder package to use it on new models Summary 1. Auto PinFinder is a must have product for Chinese Phones 2. Auto PinFinder is a must have tool to use with all current and future updates that will be made by Infinity Box ( Eliminating the need for buying new cables every time new model is updated ) Example how PinFinder can be used saving your time and money For Example You recieved a Sagem my150x to unlock You can easily unlock it with Infinity-Box, BUT cable can be an issue because it uses a new cable BUT If you have PinFinder by Infinity-Box team, it is NO PROBLEM This is how you can use it (see the picture below) 1. Run Support Manager (Infinity-Box Shell) 2. Select model Sagem my150x and check the pinout 1..........16 9: box Rx/phone Tx (RJ45 pin-3) 10: box Tx/phone Rx (RJ45 pin-2) 16: Gnd Open the Auto Pin Finder Package 3. Connect Power cable to phone instead of battery 4. Connect L16B cable (due to total number of connector pins is 16) 5. Select L16B cable in PinFinder Adapter software (according to connected cable) 6. Set Rx (box Rx/phone Tx) pin value to 9 (according to known pinout) 7. Set Tx (box Tx/phone Rx) pin value to 10 (according to known pinout) 8. Press “Power” button to enable phone power In case of connection problems it may need to change pin numbering mode (reverse pin numbering) due to different phone connector soldering to PCB. To reverse pin numbering mode from 1.....16 to 16.....1 (and vice versa)press “Reverse” button and then press “Set” button. This is just an example how you can use Sagem my150x phone with Auto PinFinder package without the need to buy new cable Similarly you can use Auto Pinfinder with current and future infinity box supported models Auto PinFinder is the most universal solution for your cable needs, just Pay once for this and eliminate the need to buy new cables again and again Make the best use of it You can use Infinity-Box PinFinder as a cable for any other box that communicate with phone via COM port (Rx/Tx/Gnd wires). You need to have Infinity-Box dongle connected to PC to use PinFinder. More information regarding Infinity-Box PinFinder is here: http://www.infinity-box.biz/index.ph...infinder&lg=en User manual for Infinity-Box PinFinder with a lot of pictures and step-by-step-instructions is here: http://www.infinity-box.biz/download..._PinFinder.pdf Last edited by InfinitySupport; 05-20-2008 at 17:43. |
The Following 140 Users Say Thank You to Infinity-Box For This Useful Post: |
05-12-2008, 21:34 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Here is PinFinder configuration file attached, more than 629 pinouts (models) is in database for manual pin selection, list of supported models become bigger and bigger every day, we will keep this thread updated. How to install manual database: 1. download attached file 2. unpack it from archive 3. copy new pinout_db_base.ini file into PinFinder folder instead of old file List of models/pinout in manual PinFinder database (27 May 2008, 48 new pinouts/models added): 3D-Sound-Bluetooth-CPU1 A808 Aiko-17G Aiko-51G Aiko-52G Airam-M342 Airness-Air99 Airness-MK99 Airness-Slide99 Airtel-Cordless_FGD8900 Alcatel-OT152 Amstrad-S288 Anycool-D66+_2sim_(MT6226) Anycool-K88-CPU1 Anycool-T808-TV-Phone Asus-V80 Audiovox-GPRS748 Audiovox-GSM609 Avivo-1960g Avvio-103A BenQ-Siemens-A38 BenQ-Siemens-A500 BenQ-Siemens-C71A BenQ-Siemens-CF51 BenQ-Siemens-CF61 BenQ-Siemens-CL71 BenQ-Siemens-E61 BenQ-Siemens-EF51 BenQ-Siemens-EF61 BenQ-Siemens-EF71 BenQ-Siemens-M100 BenQ-Siemens-M220 BenQ-Siemens-M300 BenQ-Siemens-M305 BenQ-Siemens-M315 BenQ-Siemens-M350 BenQ-Siemens-M580 BenQ-Siemens-S700 BenQ-Siemens-S88 Bird-D736 Bird-S288 Bird-S299 Bird-S570 Bird-S688 Bird-S788 Bird-V07 Bird-V708 Bleu-145x Bleu-151x Bleu-245x Bleu-354x Bleu-411x Bleu-450x Bleu-511x Bleu-551x Bleu-651x Bleu-651Z Bleu-700x Bluetooth-2600 Bluetooth-N82i Bluetooth-N958 Bluetooth-ZT588 BSNL-G200CF Cect-C2000 Cect-C600 Cect-F838-CPU1 Cect-K300 Cect-S560 Cect-T688-2sim Cect-T689-CPU1 Cect-T689-CPU2 Cect-T818_gsm+cdma Cect-T88i-2sim Cect-V180 Cect-V668 Cesim-V30 cNokia-6300 cNokia-6618-BL-A8-TV-Phone cNokia-N22 cNokia-N328 cNokia-N73 cNokia-N95 cNokia-N95_1_slider_1sim cNokia-N95_monoblock_2sim_(NHL-10) cNokia-N95-8GB cNokia-N95-Slider_2sim cNokia-N95-SlipUp cNokia-N97 cNokia-N98i cNokia-V90i Coral-200 Coral-300 cVertu-998 cVertu-Narnia-i70 Daewoo-D600 Digibee-G200CF Elson-E800 Elson-ESL808 Elson-MP500 Elson-SL308 Elson-SL900 Emblaze-Touch7 Ezio-E800 Ezio-ESL808 Ezio-MP500 Ezio-SL308 Ezio-SL900 F838-CPU1 F838-CPU2 Fly-2040 Fly-2040i Fly-B700-CPU1 Fly-B700-CPU2 Fly-E300 Fly-Hi-SLDR Fly-Hummer-HT1 Fly-LX600 Fly-MC100 Fly-MP500 Fly-MX200 Fly-MX200i Fly-MX230 Fly-MX300 Fly-MX330 Fly-SL300m Fly-SL399E Fly-SL500i Fly-SL500m Fly-SL600 Fly-SLT100 Fly-SX100 Fly-SX200 Fly-SX210 Fly-SX220 Fly-SX300 Fly-SX305 Fly-V25 Fly-V60 Fly-X3 Fly-X7 Fly-X7a Fly-Z200 Fly-Z300 Fly-Z300a Fly-Z400 Fly-Z500 Gaoxinqi-GS518-Chocolate GEO-G1 GEO-Gv880 Gradiente-GC300 Gradiente-GF500 Gradiente-GF760 Gradiente-GF910 Gradiente-GF910i Gradiente-GF930 Gradiente-GF930i Gradiente-GF950 Gradiente-GF970 Gradiente-Vibe Haier-Z1000 Huawei-T128 Huawei-T201 Huayu Hyundai-H350 Hyundai-MP318 Hyundai-MP510 Hyundai-MP718 Hyundai-MP728 Hyundai-MP738 I-Mobile-100 I-Mobile-308 I-Mobile-313 I-Mobile-508 I-Mobile-601 I-Mobile-602 I-Mobile-603 I-Mobile-611 I-Mobile-901 I-Mobile-BlackIce Inno-500 Kenuo-KN-76D_monoblock-2sim KN-Mobile-KN200 KN-Mobile-KN300 KN-Mobile-KN310 KN-Mobile-KN400 KN-Mobile-KN500 Konka-C625 Konka-C926 Konka-C966 KTech-K808 KTouch-B8890 LG-7050 LG-B2000 LG-B2050 LG-B2060 LG-B2070 LG-B2100 LG-B2150 LG-B2250 LG-C1100 LG-C1150 LG-C2200 LG-C2500 LG-C2600 LG-C3300 LG-C3310 LG-C3320 LG-C3400 LG-CG225 LG-F2400 LG-G1800 LG-G7050 LG-KE500 LG-KE600 LG-KE770 LG-KE800 LG-KE820 LG-KE850 LG-KE970 LG-KG110 LG-KG120 LG-KG130 LG-KG190 LG-KG195 LG-KG220 LG-KG225 LG-KG240 LG-KG245 LG-KG270 LG-KG271 LG-KG275 LG-KG276 LG-KG278 LG-KG280 LG-KG285 LG-KG288 LG-KG290 LG-KG291 LG-KG291i LG-KG295 LG-KG296 LG-KG320 LG-KG370 LG-KG375 LG-KG70 LG-KG800 LG-KG810 LG-KG90 LG-KP100 LG-KP105 LG-KP106 LG-KP106 LG-KP130 LG-KP200 LG-KP202 LG-KP202i LG-KP210 LG-KP215 LG-KP230 LG-KP235 LG-KU800 LG-L342i LG-L343i LG-ME500 LG-ME770 LG-ME850 LG-MG100 LG-MG101 LG-MG105 LG-MG110 LG-MG120 LG-MG125 LG-MG160 LG-MG161 LG-MG165 LG-MG180 LG-MG225 LG-MG230 LG-MG235 LG-MG280 LG-MG296 LG-MG320 LG-MG370 Libercell-KT400 Libercell-KT500 Libercell-KT8800 Lobster-485 Lobster-544 Lobster-575 Lobster-575 Micromax-X1u Mobile-Shot-TDG9922 Modelabs-Airness-Slide99 Modelabs-V-Touch Motorola-C113(a) Motorola-C114 Motorola-C115 Motorola-C115i Motorola-C116 Motorola-C117 Motorola-C118 Motorola-C119 Motorola-C121 Motorola-C122 Motorola-C123 Motorola-C136 Motorola-C138 Motorola-C139 Motorola-C140 Motorola-C141c Motorola-C155 Motorola-C156 Motorola-C157 Motorola-C168 Motorola-C168i Motorola-C257 Motorola-C261 Motorola-C300 Motorola-T191 Motorola-V170 Motorola-V171 Motorola-V172 Motorola-V173 Motorola-V175 Motorola-V176 Motorola-V177 Motorola-V690 Motorola-V872 Motorola-V878 Motorola-W150 Motorola-W150i Motorola-W170 Motorola-W170C Motorola-W200 Motorola-W205 Motorola-W208 Motorola-W209 Motorola-W210 Motorola-W212 Motorola-W215 Motorola-W218 Motorola-W220 Motorola-W355 Motorola-W370 Motorola-W372 Motorola-W375 Motorola-W377 My_Way-MW100 Nckia-M5700+CPU1 Nckia-M5700+CPU2 Nec-E121 Nec-N200 Nec-N208 Nec-N343i Nec-N910 Nec-N916 Nec-N917 Nec-N919 Nerys-N330 NewGen-C1000 NewGen-C610 NewGen-C620 NewGen-C710 NewGen-C800 NewGen-E1000 NewGen-E1100 NewGen-E1200 NewGen-Mars NewGen-S410 NewGen-T1000 O2-Jet(J1) O2-O2X1B O2-O2X1I O2-O2X2i O2-O2X3 O2-O2X7 O2-O2XLI O2-X7 Orange-TR1 Panasonic-A500 Panasonic-X200 Panasonic-X400 Panasonic-X60 Panasonic-X66 Panasonic-X68 Panasonic-X77 Pantech-C120-data Pantech-C120-gprs Pantech-C300-data Pantech-C300-gprs Pantech-C3B-data Pantech-C3B-gprs Pantech-C3-data Pantech-C3-gprs Pantech-G3900-data Pantech-G3900-gprs Pantech-G800-data Pantech-G800-gprs Pantech-G900-data Pantech-G900-gprs Pantech-GB300-data Pantech-GB300-gprs Pantech-PG-1200-data Pantech-PG-1200-gprs Pantech-PG-1210-data Pantech-PG-1210-gprs Pantech-PG-1400-data Pantech-PG-1400-gprs Pantech-PG-1405-data Pantech-PG-1405-gprs Pantech-PG-1410-data Pantech-PG-1410-gprs Pantech-PG-1500-data Pantech-PG-1500-gprs Pantech-PG-1610-data Pantech-PG-1610-gprs Pantech-PG-3000-data Pantech-PG-3000-gprs Pantech-PG-3200-data Pantech-PG-3200-gprs Pantech-PG-3210-data Pantech-PG-3210-gprs Pantech-PG-3500-data Pantech-PG-3500-gprs Pantech-PG-3500-gprs Pantech-PG-3600-data Pantech-PG-3600-gprs Pantech-PG-3810-data Pantech-PG-3810-gprs Pantech-PG-6100-data Pantech-PG-6100-gprs Pantech-PG-6200-data Pantech-PG-6200-gprs Pantech-PG-6200-gprs Pantech-PG-C300-data Pantech-PG-C300-gprs Pantech-PN210 PDA-HT508-CPU1 PDA-HT508-CPU2 PDA-TV-Mobile-A9000 Philips-192 Philips-768 Philips-960 Reliance-Classic-7310 Reliance-Classic-7610 Sagem-my150x Sagem-my200c Sagem-my220v Sagem-my220x Sagem-my300c Sagem-my301x Sagem-my411v Sagem-my700X Sands-A203-CPU1 Sands-A203-CPU2 Siba-2632-CPU1 Siba-2632-CPU2 Siemens-AP75 Sitronics-SM8190 Sitronics-SM8290 Skyzen-EZ200 Skyzen-EZ400 Skyzen-EZ500 Skyzen-EZ600 Skyzen-EZ700 Skyzen-EZ800 Sony-Ericsson-J100(i) Sony-Ericsson-J110 Sony-Ericsson-J110i Sony-Ericsson-J120 Sony-Ericsson-J120i Sony-Ericsson-K200i Sony-Ericsson-K205i Sony-Ericsson-K220i Sony-Ericsson-K310 Sony-Ericsson-K320 Sony-Ericsson-K510 Sony-Ericsson-K550 Sony-Ericsson-K60x Sony-Ericsson-K610 Sony-Ericsson-K618 Sony-Ericsson-K750 Sony-Ericsson-K758 Sony-Ericsson-K790 Sony-Ericsson-K800 Sony-Ericsson-K810 Sony-Ericsson-S500 Sony-Ericsson-T250 Sony-Ericsson-T250i Sony-Ericsson-T280 Sony-Ericsson-V600 Sony-Ericsson-V630 Sony-Ericsson-W200 Sony-Ericsson-W300 Sony-Ericsson-W550 Sony-Ericsson-W600 Sony-Ericsson-W610 Sony-Ericsson-W700 Sony-Ericsson-W710 Sony-Ericsson-W800 Sony-Ericsson-W810 Sony-Ericsson-W830 Sony-Ericsson-W850 Sony-Ericsson-W880 Sony-Ericsson-W888 Sony-Ericsson-W900 Sony-Ericsson-Z250 Sony-Ericsson-Z250i Sony-Ericsson-Z310 Sony-Ericsson-Z320 Sony-Ericsson-Z320i Sony-Ericsson-Z520 Sony-Ericsson-Z525 Sony-Ericsson-Z530 Sony-Ericsson-Z550 Sony-Ericsson-Z558 Sony-Ericsson-Z610 Sony-Ericsson-Z710 Spice-D80 Spice-S540 Spice-S800 Spice-S900 Spice-S900 TCL-3188+ TCL-3188M TCL-3188U TCL-718 TCL-728 TCL-738 TCL-GQ05 TCL-Q510 TCL-Q515 TCL-Q550 TCL-T550 TCL-T939 Telit-T200 Telit-T250 Thomson-TN320 TOCS-C64 Toshiba-TS605 TV200-2sim TV2200 TV7700 TV-Bluetooh-8928 UTstarcom-GPRS748 UTstarcom-GPRS758 UTstarcom-GPRS778 UTstarcom-GPRS779 UTstarcom-GSM708 UTstarcom-GSM718 UTstarcom-GSM719 Virgin-Fly-SX200 Virgin-Lobster-485 Virgin-Lobster-544 Virgin-Lobster-575 Virgin-V-Touch VK-Mobile-VG207 VK-Mobile-VK207i VK-Mobile-VK500 VK-Mobile-VK518 VK-Mobile-VK520 VK-Mobile-VK530 VK-Mobile-VK530 VK-Mobile-VK540 VK-Mobile-VK550 VK-Mobile-VK560 VK-Mobile-VK570 VK-Mobile-VK580 VK-Mobile-VK800 VK-Mobile-VK900 Vodafone-125 Vodafone-126 Vodafone-225 Vodafone-226 Vodafone-226FM Vodafone-227 Vodafone-228 Vodafone-527 Voxtel-1iD Voxtel-2iD Voxtel-3iD Voxtel-BD50 Voxtel-BD60 Voxtel-RX11 Voxtel-RX800 Voxtel-V350 Voxtel-V50 Voxtel-V500 Voxtel-VS800 Wellcom-W819 Zetta-A10 Zonda-G1840 Zonda-G1860 Zonda-G1880 Zonda-G1930 ZTC-ZT1689 ZTC-ZT188 ZTC-ZT321-TV-Mobile ZTC-ZT588-2sim ZTC-ZT6698 ZTC-ZT868 ZTC-ZT8899 ZTC-ZT8900 ZTC-ZT968 ZTE-125 ZTE-201 ZTE-2010 ZTE-202 ZTE-203 ZTE-204 ZTE-225 ZTE-226 ZTE-227 ZTE-231 ZTE-7310 ZTE-7610 ZTE-A12 ZTE-A12+ ZTE-A15 ZTE-A16 ZTE-A35 ZTE-A36 ZTE-A37 ZTE-A39 ZTE-A61 ZTE-A62 ZTE-A80 ZTE-Coral-200 ZTE-WP626 Last edited by InfinitySupport; 06-22-2011 at 10:16. |
The Following 136 Users Say Thank You to InfinitySupport For This Useful Post: |
05-13-2008, 13:49 | #11 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | this data base file will save lots of time thanks to infinity team. this can be used with any other box wich supports [usb to serial] if you can edit comport number in the [other box] software, then you can use Pin Finder [as a cable]. BR Mansi |
The Following User Says Thank You to mansi For This Useful Post: |
05-13-2008, 14:29 | #13 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
You need to have Infinity-Box dongle connected to PC to use PinFinder. | |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
05-13-2008, 16:07 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | 90 new pinouts added today, new database file is attached here: http://www./showpo...93&postcount=2 |
The Following 13 Users Say Thank You to InfinitySupport For This Useful Post: |
Thread Tools | |
Display Modes | |
How to use SpiderMan for Sagem, LG, SE, Motorola, Pantech, Fly, O2, ZTE etc. | hamada33r | SpiderMan | 13 | 11-16-2008 16:04 |
how to use pinfinder for china | rajendrakumar | Infinity-Box | 1 | 10-02-2008 21:23 |
UNLOCK MY150x: How to use PinFinder with Sagem and other models | alamgarh | Infinity-Box | 22 | 07-13-2008 13:57 |
How to use pinfinder with Pantech PG-C3B | -luigi- | Infinity-Box | 5 | 05-23-2008 02:49 |
How to use patch for DB2020 SE phones? | vetas | Universalbox | 6 | 03-25-2008 14:28 |
