07-12-2008, 18:09 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 765141 Status: Offline Thanks Meter: 661 | 12 July 2008, Unlock Support for Nokia 2630 added ( You must have main software installed to use this update ) Whats New Added Support for SP Unlock Nokia 2630 ( RM-298) ver 4.21, 4.90, 5.20, 5.22, 5.61 More Updates coming soon ..... |
The Following User Says Thank You to NFF Box Team For This Useful Post: |
07-12-2008, 23:52 | #5 (permalink) |
Insane Poster Join Date: Dec 2007 Location: bogor JA-BAR
Member: 655621 Status: Offline Sonork: WISE Guy Thanks Meter: 9 | thx for NFF-BOX Team,more...&more... up-date..... Thx,for NFF-BOX Team.... probem open NFF.exe had fixed....!!! More up-date for accuration fault finder Example : 1.DEAD PHONE may be first step for board who 1st boot ok!(upp ok! +id upp appear) 2nd boot ok(ic flash ok+id flash appear) solution 1:try to flash the phone,make sure the last version!!!(don't say - heat the ic & reball,rechange & see the result) When flashing can't complate (for combo ic/diferent ic) Solution 2 :-for combo ic = Ceck vbb,heat the ic,reball & rechange & make sure the range not broken & try to reflash again & see the result -For some variant who have some different ic = saw address error at ic = Ceck vbb,heat the ic,reball & rechange & make sure the range not broken & try to reflash again & see the result Example : 2.NORMAL PHONE It's mean phone can get test mode/local mode (can appear in lcd screen if lcd normal) For these case NFF-BOX use for detect ic procentase (in selftest function) and more...and more... I hope NFF-BOX TEAM more working hard & I believe you are! make it NFF-BOX it's best seller & best the trust faulty finder & solution GOOD LUCK!!! NFF-BOX TEAM..... I WAIT FOR YOU UP-DATE NEXT... SALOOM...''OVI''Cell |
07-13-2008, 07:20 | #6 (permalink) | |
Junior Member Join Date: Mar 2006
Member: 247371 Status: Offline Thanks Meter: 1 | Quote:
This dongle does not work ... install setup ... then update ... not habre software .. there is no upgrade tool in support nff help dongle is 6F63D35F35DDE41F287063F3 | |
07-14-2008, 21:02 | #12 (permalink) |
Member: 247371 Status: Offline Thanks Meter: 1 | Ok goes down(go down) upgrade tool .. execute and I end now I open the software nff version 3.11 opens one sees .. but it(he,she) lasts 5 seconds and is closed. First install setup 3.00 then update 3.11 Then that this badly? For that it me does not work .. already probe in 5 computers |
The Following User Says Thank You to jhvmovil For This Useful Post: |
07-18-2008, 05:27 | #14 (permalink) | |
Member: 655621 Status: Offline Sonork: WISE Guy Thanks Meter: 9 | re-ply can't open NFF.exe,try these one Quote:
So uninstall box driver and try install again with oryginal driver by sarassoft. good luck and tell me it's work?! | |
07-18-2008, 05:37 | #15 (permalink) |
Member: 655621 Status: Offline Sonork: WISE Guy Thanks Meter: 9 | Some triks to always conecting when klik conect to box Hi...,guy I have some triks for probem conecting box. try these one..,when we choice the box and click conect (in NFF.exe menu),the cursor put away from NFF.exe menu,click right on mouse pad (same as to re-fresh pc,but don't click re-fresh),crinngggg..always conecting...! good luck..!(I had try many and many times,it's 100 % work) |
Thread Tools | |
Display Modes | |
01 July 2008 Unlock added for Nokia 2660 and 5000 ( First in the World ) | NFF Box Team | Nokia Fault Finder Box | 26 | 11-18-2008 07:46 |
NFF-BOX Update :SP Unlock Support for Nokia 2630 added | NFF Box Team | Service Products News & Updates | 0 | 07-12-2008 18:15 |
01 July 2008 Unlock added for Nokia 5000 ( First in the World ) | NFF Box Team | Service Products News & Updates | 0 | 07-01-2008 10:48 |
There is no unlocking support for Nokia 2660 in new hwk 2.0.6.0 | milkyctg | HWK | 0 | 11-12-2007 00:57 |
Pls! unlock support for Nokia 1112 & 2610 | mtb116 | Universalbox | 14 | 09-28-2006 20:35 |
