07-15-2008, 13:24 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: E.A.P & E.A.S
Member: 76239 Status: Offline Sonork: 100.1584414 Thanks Meter: 210 | YESSIM big problem with LG KH1200 1. Reading Yessim info .. Reading Yessim SN..OK. Yessim SN : 01A***xx Frimware version : Yessim Firmware V:2.4 Beta (c) MCC-MNC : 001-01 Mode : Normal Mode. IMSI Patch Count : 30 result : Phone work normal for about 3 hours and then show "Not Location Update registered Emergency call only" 2. Reading Yessim info .. Reading Yessim SN..OK. Yessim SN : 01A***xx Frimware version : Yessim Firmware V:2.4 Beta (c) MCC-MNC : 510-11 Mode : Normal Mode. IMSI Patch Count : 30 result : "Invalid card in this region" 3. Reading Yessim info .. Reading Yessim SN..OK. Yessim SN : 01A***xx Frimware version : Yessim Firmware V:2.4 Beta (c) MCC-MNC : 001-01 Mode : Boost Mode. IMSI Patch Count : 30 result : "Insert USIM card" any other solution ? thanks in advance |
07-16-2008, 17:06 | #2 (permalink) | |
Freak Poster Join Date: Jun 2008
Member: 799206 Status: Offline Sonork: 100.67372 Thanks Meter: 276 | Quote:
Pls contact me on Yahoo messenger we know what is the problem. We need test together pls contatc me urgent | |
07-17-2008, 14:11 | #3 (permalink) |
Member: 76239 Status: Offline Sonork: 100.1584414 Thanks Meter: 210 | OK finally problem solved, phone come with stabil signal, with nice trick, best with YESSIM ... for trick contact me or your reseller ... thanks |
07-17-2008, 18:07 | #6 (permalink) |
No Life Poster Join Date: May 2007 Location: Alien Nation
Member: 515413 Status: Offline Thanks Meter: 146 | contact me by Pm bos.. [email protected] |
07-18-2008, 06:34 | #7 (permalink) |
No Life Poster Join Date: Jun 2005 Location: insane in da mad brain Age: 46
Member: 154522 Status: Offline Thanks Meter: 48 | for kh1200 lg cyon korean 3G setting : Normal mode 00101 patch count =7 but we will have registering poroblem, so to solved it you need to write your own number into your sim card. ussually i used motorola phones for write my own number. but dont forget also to change network into gsm mode (900/1800) or 1900 mode. tested by me for all yessim user. regards |
The Following User Says Thank You to freakyass For This Useful Post: |
08-30-2008, 18:28 | #8 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: CELLULARLABS TEAM-SOLO-INA
Member: 288188 Status: Offline Thanks Meter: 24 | Quote:
please...step by step explanation br | |
08-31-2008, 06:25 | #9 (permalink) | |
Freak Poster Join Date: Dec 2004 Location: Z3x
Member: 98342 Status: Offline Sonork: 1641338 Thanks Meter: 19 | Quote:
another trick??? | |
08-31-2008, 07:31 | #10 (permalink) |
No Life Poster Join Date: Feb 2004 Location: PaKiStAn Age: 44
Member: 51639 Status: Offline Thanks Meter: 76 | i have the same problem with 6120 Frimware version : Yessim Firmware V:2.4 Beta (c) MCC-MNC : 001-01 Mode : Boost Mode. IMSI Patch Count : 30 Frimware version : Yessim Firmware V:2.4 Beta4 MCC-MNC : 001-01 Mode : Boost Mode. IMSI Patch Count : 30 but result insert simcard phone lock on Uk 3G also tried on UK3g but no luck what should i do now??? |
big problem with LG CE110 !! | humbedj | VygisToolbox | 1 | 07-03-2008 23:28 |
A big Problem with Lg | kamran_s | Nokia Hardware & Hardware Repair | 0 | 02-06-2008 05:42 |
A big Problem with Lg | kamran_s | LG | 0 | 02-06-2008 05:40 |
Big problem with LG L5100 | distefano | VygisToolbox | 3 | 12-27-2005 03:19 |
Big problem with LG C2200 | hitibiti | Blazer | 26 | 06-05-2005 09:29 |
