09-07-2008, 00:04 | #1 (permalink) |
Junior Member Join Date: Sep 2008
Member: 854862 Status: Offline Thanks Meter: 2 | SIM MAX help please? I managed to crack the KI on old VoiceStream SIM (Pre T-Mobile days, haha) i had laying around. heres that info, taken off woronscan (bits emitted for privacy) Code: KI : 7F ** C9 ** 1B ** 4D ** EB ** 1C ** 3B ** 02 ** IMSI: 08 ** 01 ** ** ** ** ** ** ICC : 89***************27 so heres my question: after trying to erase all enteries, and loading it up into SimScanner, when i try to read/write it says "Invalid Card".. MagicSim still reads all my enteries properly, and when i pop the sim into a phone it sees all the enteries just fine.. but the KI is wrong so none of the options authenticate properly. how can i fix this?! if someone can instruct me as to how i can either use MagicSim, or format my sim to be able to use SimScanner again, please let me know! EDIT: i've made some progress i think.. i entered in 00000000000000000000000000000000 as KI and MagicSim outputs 8FD131136E510EA98FD131136E510EA9. Code: 0000000000000000 00000000000000000 8FD131136E510EA9 8FD131136E510EA9 heres output of 10000000000000000000000000000000: Code: 1000000000000000 0000000000000000 28C41AB4B2EA2DF4 8FD131136E510EA9 and FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF: Code: FFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFF 4646249F559F15BA 4646249F559F15BA this is very confusing! =[ Last edited by haykuro; 09-07-2008 at 00:12. |
09-07-2008, 15:54 | #5 (permalink) |
Member: 854862 Status: Offline Thanks Meter: 2 | http://sim-max.biz/download/download.php direct link to latest version (i attatched the copy as well just in case the link goes down) SimScanner 10.0 seems to be a modded version from china it came with a disk i got along with my SimMax reader/writer + 16in1. (the entire damn disk is in chinese though, if anyone is willing to translate ill make an ISO ) anywho.. i uploaded both files to mediafire (10 MB for the chinese version, and 13 MB for the original) http://www.mediafire.com/?sharekey=5...db6fb9a8902bda any word on what might be my problem guys? i'd really like to be able to use my SimMax card! =[ |
09-07-2008, 17:06 | #6 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Phoenix DeCoder Service NLD
Member: 525282 Status: Offline Thanks Meter: 541 | Quote:
09-07-2008, 18:29 | #8 (permalink) | |
http://rapidshare.com/files/14340464..._6.3_.rar.html | |
09-07-2008, 18:33 | #10 (permalink) | |
No Life Poster Join Date: Nov 2003 Location: GT
Member: 44659 Status: Offline Thanks Meter: 363 | Did you scanned the SIM MAX, if so is trashed ... Quote:
The Following User Says Thank You to luzer For This Useful Post: |
09-07-2008, 18:40 | #11 (permalink) |
Member: 854862 Status: Offline Thanks Meter: 2 | no, i never scanned it. (i read the manual first) the card still works, i can read/write to it with MagicSim but its not working with anything else. =[ EDIT: simmax 6.3 has same results (blank + invalid card) |
09-07-2008, 23:06 | #12 (permalink) |
Freak Poster Join Date: May 2004
Member: 66471 Status: Offline Thanks Meter: 7 | If it is acceptable you can use the obtained values of Ki/IMSI/ICCID in Silver/Green cards by means of Configurator 16in1 by Pic-ador: http://borozda.com/pic-ador/ I use this software for years and only two minor bugs have been encountered: 1) the last four positions (## C-F) loose SMSC numbers (one have to put down them manualy - only once of course 2) rather weird behaviour in some menu items if you cut menu in the Configurator (has no influence on functioning and switching between positions). |
09-07-2008, 23:25 | #13 (permalink) |
Member: 854862 Status: Offline Thanks Meter: 2 | Hello, i tried to use the program you gave me and i put in this information: but when i try to load the outputted flash and EEPROM i get an error! Sim-Emu 6.01: "This is not a Sim-Emu 6.01 Flash File" Sim-Emu Configurator v1.12d: asks for flash, then when asking for eeprom gives "Unknown version" Sim-Emu Configurator v1.160d: asks for flash, then when asking for eeprom gives "Unknown version" some help please? |
The Following User Says Thank You to haykuro For This Useful Post: |
09-07-2008, 23:40 | #14 (permalink) |
Member: 66471 Status: Offline Thanks Meter: 7 | I haven't caught - where did you want hex-files 'to load'? You fill necessary positions starting from 0 - you've done it as i see. Then save CFG file for further possible editings. Then - generate flash/hex and eeprom.hex. These files afterwards should be written on to Silver/Green2 cards by means of appropriate software. I use IC-Prog 1.05C choosing PIC 16F877 to program flash and 24C64/AT 24C256 as eeprom device for Silver/Green2 cards respectively. Hint: you should use 'verifying during writing' option - otherwise would get error checking (or verifying - do not remember exactly) since reading internal flash eeprom is forbidden. |
09-07-2008, 23:45 | #15 (permalink) |
Member: 854862 Status: Offline Thanks Meter: 2 | i was trying to write to card using Sim-Emu, but nevermind. do you happen to have Card Master 2.1 (or higher)? IC-Prog is a little confusing for me, and i heard it can mess up the Sim Max reader if you do something wrong. =[ |
Sim Max Help Please First Time User | radiowizard | Sim Cloning and Scaning | 0 | 01-30-2008 10:33 |
Motorola v300 keep saying "insert sim card" help please | toukour | Motorola P2k | 3 | 07-05-2007 23:38 |
r 220 sim way help please | afser | Samsung Hardware Repair | 0 | 12-24-2005 12:42 |
lg 5600 DEAD with sim,without sim on HELP please | mohammed | Hardware Repair by brands | 1 | 09-24-2005 18:20 |
Motorola v300 "insert sim card" help please | toukour | Motorola P2k | 0 | 07-27-2004 18:57 |
