Old 03-09-2007, 12:03   #1 (permalink)
mobilelatham's Avatar
Member: 306991
Thanks Meter: 62
Phoenix Service Software 2007.04.0.1
Dongle Crack
Phoenix 2006 crack
Nemesis Service Suite
Nokia Diego 3.09
Phoenix Service Software 2006.44.6.163
Phoenix Service Software 2007.04.0.1 Patch
^All The Above Are Mega Upload
INSTALL DIEGO
1. Run and install the following file: Diego 3.09.msi
If you get an error during the installation, it’s because you didn’t uninstall the Nokia connectivity cable driver!
2. INSTALL PHOENIX SERVICE 2006 WITH THE CRACK
3. Open The Dongle Crack First. Just Open It, Don’t Run It Now
4. Start installing phoenix 2006. During The Installation You’ll Get An Error Message.
5. Press on “Retry” and run the crack immediately after! (Check that the destination folder is Windows/system32). If you’re not fast enough, the message will reappear and you’ll have to re-run the crack the same way as above (but faster…)
6. You’ll get 2 error messages, "DESKEY" Just Press OK, And Then Finish.
7. Run Phoenix 2006 crack
8. Restart your PC.
9. INSTALL PHOENIX 2007
10. Run Phoenix Service Software 2007.04.0.1 Patch
11. Open The Dongle Crack First. Just Open It, Don’t Run It Wow!
12. Start Installing Phoenix 2007. During The Installation You’ll Get An Error Message.
13. Press on “Retry” and run the crack immediately after! (Check that the destination folder is Windows/system32). If you’re not fast enough, the message will reappear and you’ll have to re-run the crack the same way as above (but faster…)
14. You’ll get 2 error messages, "DESKEY" Just Press OK, And Then Finish
Restart your PC.
now you can run Pheonix 2007 you might need to install Phoenix 2006 crack again i did'nt.
The Following 9 Users Say Thank You to mobilelatham For This Useful Post:
Old 03-09-2007, 12:59   #2 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
Can You Help us How to install this pheonix.
Do you tried it? It's working or not?
thks
Old 03-09-2007, 13:25   #3 (permalink)
Member: 306991
Thanks Meter: 62
100% working same install as before install 2007.04.0.1 last
The Following User Says Thank You to mobilelatham For This Useful Post:
Old 03-09-2007, 13:41   #4 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
Look at these Stypes if it's wrong plz correct me:
Step N° 1 - INSTALL DIEGO
- Run and install the following file: Diego_3_09.msi
- If you get an error during the installation, it’s because you didn’t uninstall the Nokia connectivity cable driver!
Step N° 2 - INSTALL PHOENIX SERVICE 2004 WITH THE CRACK
- Open the crack first. Just open it, don’t run it now!
- Start installing phoenix 2004. During the installation you’ll get an error message.
- Press on “Retry” and run the crack immediately after! (Check that the destination folder is Windows/system32).
- You’ll get 2 error messages, just press OK, and then Finish.
- You successfully installed phoenix service 2004.
Restart your PC.
Step N° 3 - INSTALL PHOENIX 2007
You have the shortcut for Phoenix on your desktop. Run it, and you might get several times the message "dskey not found!”. This is normal, just press « ok », and eventually Phoenix should open.
- Don’t close the program. You must only minimize the window.
- Run phoenix_service_sw_2006_44_6_163.EXE. You shouldn’t have any error!
- Make sure you don’t restart the PC at the end of the installation. Just choose "restart my PC later" and then Finish.
Now you can close the window of Phoenix that you have minimized.
Go to the folder Program files/Nokia/phoenix and copy this entire folder on your desktop.
Restart your PC.
If you have any error messages after the reboot, just press « Cancel ».
Go to /Program files/Nokia/, delete the folder phoenix, then replace it by the folder that you saved on your desktop. Now Re-run the crack of Phoenix 2004.
You can now run Phoenix 2006.
But How to do with Pheonix 2007.
thks
The Following User Says Thank You to gsm99 For This Useful Post:
Old 03-09-2007, 13:59   #5 (permalink)
Member: 306991
Thanks Meter: 62
I Placed instructions in my first post
Old 03-09-2007, 15:01   #6 (permalink)
Member: 464665
Thanks Meter: 4
Restart your PC.
Restart your PC.
thks
The Following User Says Thank You to khan7589082 For This Useful Post:
Old 03-09-2007, 15:12   #7 (permalink)
gsm99's Avatar
Member: 104737
Thanks Meter: 76
@khan;
Good copy and past
Old 03-13-2007, 00:26   #8 (permalink)
Member: 339689
I am in Brazil and can't download from megaupload. Could you upload Phoenix 2007 update at rapidshare or other?
Old 03-13-2007, 00:30   #9 (permalink)
Member: 306991
Thanks Meter: 62
Torrent mate
BB5 Flash Kit
The Following 2 Users Say Thank You to mobilelatham For This Useful Post:
Old 03-13-2007, 05:28   #10 (permalink)
Member: 217580
Thanks Meter: 1
When I install pheonix 2007, there is no error message, but after install, it show sucess install, but when I open pheonix, I found that it is still 2006 ver, why and any idea?
best regards
alex
Old 03-13-2007, 10:49   #11 (permalink)
Member: 306991
Thanks Meter: 62
as i find it is only an update on models supported
Old 03-14-2007, 11:12   #12 (permalink)
Member: 467667
Thanks Meter: 1
Thanks. worked great.
I have modified the dongle crack so that you can run it before clicking 'retry' and don't need fast fingers.
Dongle Crack
Instructions:
1. Uninstall everything nokia related on your computer and reboot.
2. Download...
from the first post:
Phoenix 2006 crack
Nokia Diego 3.09
from this post:
Dongle Crack
3. Run and install the following file: "Diego 3.09.msi"
4. Run and install "Phoenix Service Software 2006.44.6.163.exe"
During The Installation You’ll Get An Error Message. Don't click retry or cancel.
5. Run "Dongle Crack.exe"
6. Click retry in the Phoenix Service Software setup and complete installation. Reboot.
7. After reboot Phoenix will continue installing. You’ll get 2 error messages, "DESKEY" Just Press OK, And Then Finish.
8. Run "Phoenix 2006 crack.exe"
9. Run "Phoenix Service Software 2007.04.0.1 Patch.exe"
You're done
The Following User Says Thank You to uryan For This Useful Post:
Old 03-14-2007, 19:03   #13 (permalink)
Member: 249141
GREAT THANK'S.I FINALLY SUCCEEDED TO GO BACK TO REGULAR VERSION OF N73 3.0704.1.0.1 FROM N73 ME 3.0705.1.0.31 WITH PHOENIX LATEST VERSION DESCRIBED BY mobilelatham.
Old 03-14-2007, 19:08   #14 (permalink)
Member: 269021
Thanks Meter: 87
Why u go back to old version for ? ME is da best & audio is loud n da music player is like n91
Old 03-15-2007, 05:00   #15 (permalink)
Fazil's Avatar
Member: 282757
Sonork: 100.1606418
Thanks Meter: 34
Originally Posted by mobilelatham View Post
Torrent mate
BB5 Flash Kit
please send me the invitation ( [email protected])
Phoenix Service Software 2007 12 6 27689. Diego 3.09, NSS mobilelatham Nokia Base Band 5 ( BB-5 ) 15 08-16-2007 18:47
NEW Release for PHOENIX SERVICE SOFTWARE 2007.12.6.27689 zabhi Nokia Base Band 5 ( BB-5 ) 14 08-15-2007 19:17
Help Phoenix Service Software 2007 12 6 27689 zabhi Nokia Base Band 5 ( BB-5 ) 1 08-07-2007 12:32
Please try it with Phoenix Service Software 2007.4.6.170 david88 Nokia Base Band 5 ( BB-5 ) 1 07-22-2007 15:05
Page generated in 0.24337 seconds with 10 queries
